2003 C5 Persisting radio issue
Old May 22, 2023 | 05:57 PM
cubx79's Avatar
cubx79
Cruising
Default 2003 C5 Persisting radio issue
So I am going crazy here. I'm STILL having issues with this stereo system.
So to start out I had a double din touch screen connected to the Bose stuff via a pac adapter. I thought maybe I was losing bass when over taxing the system. But im thinking now, I was actually losing speakers.
So I upgraded and replaced all the Bose speakers and ran them to an amp. Same issue. But this time, everything on the amp (rcas) was cutting out. I've changed head units, ive changed amps, checked wires, replaced the amp power wire and ground, added a capacitor. Same f**king issue. It's driving me nuts. Can the pac adapter or maybe the Bose processor be screwing with something and is there another harness adapter I can use since the Bose stuff is gone? I've checked every wire. But like I said. I had this issue before changing speakers and the add ons.
Old May 22, 2023 | 05:59 PM
JMG2's Avatar
JMG2
Moderator
how are you grounding the amp?
there are only a few grounding spots on the vette, make sure they're all clean. a good portion of the time bat **** nutty electrical gremlins are ground issues.
Old May 22, 2023 | 06:09 PM
cubx79's Avatar
cubx79
Cruising
I have aftermarket seats. So to the bracket. Other places are saying it might be the pac adapter messing up
Old May 23, 2023 | 02:19 AM
Moved to C5 Tech. You might also want to post a link to this in the Audio/Electronics section.
Old May 23, 2023 | 06:02 PM
jdewolf's Avatar
jdewolf
You want the ground to be as short as possible. I imagine running it to the seat bracket required at least 2 feet of wire.
Also if you have an aftermarket head unit, amp and speakers... ditch the PAC as you no longer need it. Use a Scosche GM02B harness.
Old May 24, 2023 | 01:25 AM
SilverC54me's Avatar
SilverC54me
You don't need the PAC adapter if you are going fully aftermarket. Also don't use the seat bracket to ground the amp. At the bottom of both B pillars is a chassis ground, use that instead.
Also use the accessory power tap in the passenger foot well to power the head unit. there is switched and constant power wires as well as a ground in it. The tap is next to the BCM it is a 3 pin plug with yellow, orange and black wires coming off of it.
Gary
Old Jun 10, 2023 | 12:19 AM
cubx79's Avatar
cubx79
Cruising
Ok. Some updates. I took out the pac adapter box and left the harness adapter, tidied up some wires. Everything seemed to work fine for a week. Hell, the stereo even sounded better without the box for whatever reason. Also went in and took out the "buttstop" on the orange wires in the doors and checked all connections.
The previous owner already did the power tap. I'll try moving the ground in the next few days and order another harness adapter.
Old Jun 10, 2023 | 01:44 AM
larney's Avatar
larney
Where are you getting the power for the amp? Where is the amp located? I had an issue
and I traced it it to a combination of too long a run for the amp power wire(it was 8 ga too) and the ground wire.
Moved the amp to behind pass seat (it was in the rear hatch area between the tail lights, and washer with ground
on seat. No issues and sounds great. I kept the PAC in so I could retain the music on function. But that's the only
thing I used it for.
Old Jun 10, 2023 | 07:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
MAKE SURE THAT, you are getting full voltage and current from the source that you have selected for you switched power. Our ignition switches are well known for going to hell and outputting partial voltage to the loads.
Put a volt meter on the fuse test points to chassis ground and crank the unit to failure. If the voltage drops below battery voltage under load, there's your issue. Seen this 50 times for several failures.
You may need to add a relay between switched power source and a dedicated battery power lead.
Bill
To 2003 C5 Persisting radio issue
