Please help me diagnose mechanical discrepancy
Within the last 800 miles, on 3 occasions ive been driving the car at a comfortable cruise speed above 50mph and the car will abruptly lose speed with a sort of jerking motion. The whole event only lasts about a split second, not too dramatic. It will jerk once or twice very quickly and then go back to normal. It sort of felt like something behind the car had it on a rope and just tugged it once or twice. Its only happened 2 or 3 times in 800 miles.
Ive never experienced this on any vehicle so i dont know where to begin with diagnostics. I do my own work so i can check things out, but i wanted to see if anyone else here has experienced this before.
My first suspect is the clutch because its still original, but ive never been in a car with a slipping clutch to know what it feels like. The car is still holding RPMs and accelerating as expected all the way to redline, although i have always purposely slightly short shifted the car. I change the clutch fluid weekly via the ranger method and the dot 4 fluid stays clear. There hasnt been any pinging/metalic/knocking sounds.
Second suspect maybe a bad spark plug(?)
Any opinions would be appreciated.
Thanks!
RFA: 2100, 2105, 2110, AND 2115. (All TPMS codes)
This is because im running the car with no tpms sensors, have been for years. It hasnt been a problem so id say its safe to dismiss that as a cause.
NEXT: This is the important part and proper steps to help figure out where to start:
With a clean DTCs slate, the very next time it farts, IMMEDIATELY look at the CEL indicator and see if is flashing. A flashing CEL normally indicates an engine misfire. It will flash during the event and stop when the misfire stops. A FLASHING CELL, normally sets a PCM P-0300 DTC.
NEXT: Safely pull off the road and stop the vehicle. WITHOUT TURNING OFF THE IGNITION, press and hold the RESET button to clear any messages displayed in the DIC. Then use the OPTIONS and FUEL buttons to enter the C5 internal DTC reading routine. Enter manual mode and scroll through ALL the modules and report any and all DTCs that are present.
I seriously doubt you have a clutch issue. It Sounds like you lost Power to the PCM for an instant and then regained it. Just like you turned the ignition switch off and then back on. If that sort of problem happened, it normally does NOT leave any DTCs.
Reading the DTCs will tell us if a monitored module is having an issue. If no DTCs are present, we will be looking foe a POWER or GROUND disruption somewhere.. FIRST STEPS!
Bill
Bill
BET YA, you find loose spread damaged pins. There's your issue!!!
OH, I helped TWO other forum members with this very issue in the past couple of weeks. BAD/SPREAD FEMALE PINS in the ignition switch connector.
Bill
