Service vehicle soon
Few time ago came “service vehicle soon” light. For now every time when I start car and ABS and traction control light will on. Its blinking about 20min.
and today came extra “reduced power” and if I looked fault codes and there was many:
P0135
P0141
P0155
P0161
P1571H
P1630
P1689H
B0432
U1040H
B2284H
B2285H
C2120H
Can anyone advise what to check?
Second, CLEAR ALL of the DTCs. Turn the Ignition OFFF. NEXT- Restart the engine. WITHOUT turning the ignition / engine off, Use the RESET button to clear any of the DIC Messages. Press/Hold reset until they clear.
Next, READ the DTCs WITHOUT turning the ignition OFF.
List ALL of the new DTCs and make sure to list if they are CURRENT "C" or HISTORY "H"
Give us that NEW info.
NOTE! Its important to read the DTCs in the same ignition cycle WITHOUT turning the ignition off. Some DTCs clear them selves or turn to history once the ignition is turned off and then back on.
Bill
U1040 H C
B0431 H C
P1630 H
I mentioned if I turn ignition off for few seconds and then on( not starts) and then came “reduced power” and one extra fault was P1221.
Is this normal that menu 28-TCS are- NO COMM. when engine is run?
P-1221 Fuel Pump Relay control circuit OPEN or SHORTED. Remove the Fuel Pump Relay. Carefully examine the Pins on the relay and the female pins in the fuse box. Look for corrosion, darkening of the pins, spread female pins in the fuse box. Get an old fuse. Break it in half. Use the half of the fuse to insert into the female pins in the fuse box. When you insert or extract the fuse half in the fuse box female pins, you should feel a nice tight grip on the fuse blade.
In MY honest opinion, You have to fix the 1630 as it is preventing you from cranking/starting the engine. Purchase a NEW Lock Cylinder/VATs Module. If you remove the ignition switch, you can take the ignition switch and the new lock cylinder to GM Dealer OR a Locksmith and have it rekeyed to match you OEM Key. To be SURE if the VATS module is reading the key chip, you can disconnect the VATS pigtail and read the two wires with an OHM Meter. It should match the resistance of the little Resister chip in your key. Then you have to make sure that it getting to the BCM.
As C5 DIAG stated, the ignition powered modules are pretty predictable indicators of a faulty ignition switch contact/s.
It looks like your switch is most likely working on that last ignition cycle. Maybe it will have issues on the next or day after.
