Help!
Old Aug 8, 2023 | 10:25 PM
Tayden's Avatar
Tayden
3rd Gear
Default Help!
Ok so I have a 1998 c5 corvette and the other day while I was driving to work the engine just instantly cut off. Tried to start the engine and starter engages but does not turn over engine. I did notice a while back the harmonic balancer was a little wobbly while idling. Thinking the motor is probably locked up but I’m not sure. Maybe crank is broke, or seized? Hopefully not 🙏 There was no noise when engine cut off, like something breaking or what not. Also I can not currently fit any type of ratchet or wrench etc. to try and turn the engine over manually because the steering rack is right in front of the harmonic balancer :/ Im not sure what to try first, please help lol
Old Aug 9, 2023 | 12:18 AM
jim993's Avatar
jim993
If you know how, pull codes and report.
An offset 24 mm box end wrench should turn the crank.
Old Aug 9, 2023 | 12:24 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, Tayden, and congratulations on your C5!
Bummer about your problem and hopefully there will be an easy fix.
First, have you tried pulling codes from the DTC? Check here if you are not familiar with how to pull codes and what the codes mean: https://www.corvetteforum.com/forums...post1578159431
Additionally, you may want to check your battery and charging system as well as the connection to the starter.
Another consideration may be a faulty starter. If there are breakdowns within the starter (bad brushes, etc), the starter could be spinning but not generating the torque necessary to get your engine to turn over. This could make you think the engine is seized when in actuality the starter is too weak to get the engine to turn over and fire. Hopefully it is something like this and not a seized engine.
Best wishes for a simple and inexpensive fix!
Old Aug 9, 2023 | 06:18 AM
Moved to C5 Tech for more assistance.
Old Aug 9, 2023 | 03:55 PM
redzg's Avatar
redzg
Manual or 2 pedal car? If it's a manual, you can put the trans in 4th or higher, release the parking brake, and somewhat gently push the car forward to see if the engine will turn. Key off, of course.
Old Aug 9, 2023 | 07:16 PM
Tayden's Avatar
Tayden
3rd Gear
I will get one of these on my way home from work tomorrow thanks!
Also won’t be home till late tonight so will also check the codes tomorrow.
Old Aug 9, 2023 | 07:21 PM
Tayden's Avatar
Tayden
3rd Gear
I won’t be home till late tonight but I will check the codes tomorrow after work. Also I was having starting problems with the starter so what you said sounds very promising 🙏 I have already removed the starter a while back but haven’t bought a new one yet simply because I did not know if that was my problem for sure. Thanks for the info!
Old Aug 9, 2023 | 08:21 PM
redzg's Avatar
redzg
If you do get a new starter, there are many LS stories about getting a starter with two long bolts instead of one short and one long.
To Help!
