Trunk problems on convertible
Old Aug 15, 2023 | 03:35 PM
Mattbyard's Avatar
Mattbyard
4th Gear
Default Trunk problems on convertible
I have a 2000 convertible I just bought a month ago. I cannot get the trunk open. The trunk/ fog lights BUTTON doesn’t work. I checked all the fuses and harness going to trunk button. One wire is hot on the end. The old key fob didn’t work so I bought a new fob. My doors unlock and lock with new fob but trunk doesn’t open. i did change trunk relay under passenger floor board but didn’t fix.I don’t hear a noise either trying to open it. I don’t have a service manual. Can anyone please tell me a fuse number or am I missing or something else. I’m out of ideas? They are not any videos I can find on this issue online
Old Aug 15, 2023 | 03:45 PM
yellow2007's Avatar
yellow2007
Check fuse 39 in pass footwell
Old Aug 15, 2023 | 04:26 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Let me know if you need help with the wiring schematic or troubleshooting procedure…helped someone maybe 6 months ago with this issue but I can’t remember what the fix was !!
Old Aug 15, 2023 | 07:14 PM
yellow2007's Avatar
yellow2007
Getting old sucks doesn't it?
Old Aug 15, 2023 | 07:32 PM
jcgunn's Avatar
jcgunn
The fog lights will not work unless the headlight switch is in parking or higher.
Old Aug 15, 2023 | 08:08 PM
Mattbyard's Avatar
Mattbyard
4th Gear
what is parking or higher mean?
Old Aug 16, 2023 | 05:59 AM
frodo84's Avatar
frodo84
Uneducated autodidact
He means unless the parking lights are on, or the headlights are on...
Old Aug 16, 2023 | 06:14 PM
grinder11's Avatar
grinder11
What do the foglights working have to do with the trunk not opening??????
Old Aug 16, 2023 | 07:06 PM
Mattbyard's Avatar
Mattbyard
4th Gear
The button is fog lights and trunk together on my 2000 convertible. Neither works but key fob doesn’t open trunk either so it’s not the button
Old Aug 16, 2023 | 07:07 PM
Mattbyard's Avatar
Mattbyard
4th Gear
Did you read my entire post?
To Trunk problems on convertible
By Michael S. Palmer | 2026-06-03 11:00:24
