Rod bolt change
Old Jan 22, 2003 | 11:41 PM
Cya5's Avatar
Cya5
Default Rod bolt change
How hard is it to get the oil pan off with the motor in the car?
I want to change my rod bolts.
I have heard that it is not that difficult?
Old Jan 23, 2003 | 12:38 AM
jmX's Avatar
jmX
Default Re: Rod bolt change (Cya5)
I'm not sure, i'll be doing a writeup on this as soon as I can afford rod bolts. If you wanna do it at my apartment maybe I can document it for my page using your car?
Old Jan 23, 2003 | 01:04 AM
Sam Lin's Avatar
Sam Lin
Just out of curiosity, why are you changing the rod bolts? On stock motors, I don't think I've ever heard of them failing?
Thanks!
Sam
Old Jan 23, 2003 | 02:46 AM
Nitrous Nate's Avatar
Nitrous Nate
Default Re: Rod bolt change (Sam Lin)
I have a set of ARP 190,000 psi rod bolts that fit the stock rods. I have heard that you can change them with the engine still in the car. I will take $70 for them and I'll pay the shipping. They are still in the sealed package, I was going to use them but have changed my mod plans. Let me know if you guys are interested Nate
Old Jan 23, 2003 | 09:38 AM
Cya5's Avatar
Cya5
Default Re: Rod bolt change (jmX)
I am changing them because I am shooting for +650 at the wheels with my new set up. As you might expect, the stock rod bolts are not safe at that level. ;)
Thanks for the offer but I have a pretty full up shop. If you want to come over and document the change that would be cool. I will buy the beer. :cheers:
Old Jan 23, 2003 | 08:53 PM
David Plum's Avatar
David Plum
650 horsepower and you think just bolts is enough you will need rods & pistons or a broom & dust pan
Old Jan 23, 2003 | 10:09 PM
Cya5's Avatar
Cya5
Default Re: Rod bolt change (David Plum)
No, just H/C, good tuning and a procharger. :D
Old Jan 24, 2003 | 10:00 AM
FreddyG's Avatar
FreddyG
:iagree:
Old Jan 24, 2003 | 10:17 AM
jimman's Avatar
jimman
Default Re: Rod bolt change (LuvmyC5)
:iagree: plus a new gear train
Old Jan 25, 2003 | 09:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Rod bolt change (jimman)
If you change the rod bolts you will need to resize the rod ends to ensure that the alignment of the rods dont change!! :nono: If you dont you may wipe out a crank or a rod. Talk to a machine shop about rod bolt replacement prior to attempting to accomplish this on an assembled engine!
Bill C
Old Jan 26, 2003 | 02:14 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Rod bolt change (Bill Curlee)
Also DO NOT REPLACE YOUR OIL PAN WITHOUT following the proper installation procedure and insuring the proper alignment.
If you just bolt the pan back on it will crack!!!! :mad
Old Jan 26, 2003 | 03:15 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I understand the LS1 does not need the rod ends resized due to the cracked rod design. The rod is made as one parts then the end cracked apart. The end will realign on the crack from the original break.
Has anyone changed the bolts in the car. Other forums have discussed that an F-body needs the motor pulled but the C5 might be changed in the car due to the motor sitting further back in the car.
Old Jan 26, 2003 | 10:08 PM
steve keen's Avatar
steve keen
Default Re: Rod bolt change (93Polo)
TO THOSE OF YOU THAT HAVEN"T BEEN THIS FAT INTO YOUR CAR i CAN TELL YOU IT"S A PAIN IN THE butt,MOTOR MUST BE SUPPORTED FROM ABOVE WITH A FRAME OR ENGINE LIFT,FRONT CROSSMEMBER MUST BE REMOVED{WHEN ITS REMOVED NOTHING SUPPORTS THE MOTOR}REMOVEING IT ALSO REQIURES RACK BOLTS BE REMOVED{A REAL PAIN}SWAY BAR ENDS,SEPERATEING UPPER CONTROL ARMS{LOWERS GET DROPED WITH IT} ITS JUST LIKE A TRANS SWAP BUT YOUR AT THE OTHER END OF THE CAR{A CRUDE EXPLANATION} THE RODS DO NOT HAVE TO BE RESIZED OR CHECKED ,I AM BUILDING A H/C S/C MOTOR AND PISTONS ARE ALSO A MUST! HOPE THIS HELPS THANKS STEVE
Old Jan 27, 2003 | 12:59 PM
Cya5's Avatar
Cya5
Default Re: Rod bolt change (steve keen)
Thanks guys! :thumbs:
Old Jan 27, 2003 | 02:36 PM
Sam Lin's Avatar
Sam Lin
I remember reading a year or 2 ago that earlier model C5s had a one-piece oil pan, requiring the engine hoist and various shenanigans to let the oil pan clear the subframe on removal, but later models used a 2-piece oil pan, making life easy. I'm not sure though.
Sam
Old Jan 27, 2003 | 03:59 PM
Cya5's Avatar
Cya5
It is eazy (from what I understand) to remove the oil pan on the later model cars.
To Rod bolt change
