What oil in rear diff?
Old Jan 23, 2003 | 07:06 PM
whip383's Avatar
whip383
Default What oil in rear diff?
Is there special oil that needs to be put in the rear diff when changing it? Can you only get it from the dealer or are there other places?
Thanks,
Chan
P.S. Part number's and/or brands would be great. :cheers:
Old Jan 23, 2003 | 07:11 PM
Killrwheels's Avatar
Killrwheels
Default Re: What oil in rear diff? (whip383)
I'm gonna use Mobil 1 in my new differential. WCC shows GM Fluid at 75W90 I believe. Remember to add the anti-slip additive also. :thumbs:
Old Jan 23, 2003 | 07:23 PM
IMQUIK's Avatar
IMQUIK
AMSOIL Series 2000 75w90 Gear lube for me. No need to add the additive, it's in it.
http://www.amsoil.com/products/tgr.html
Old Jan 23, 2003 | 07:44 PM
whip383's Avatar
whip383
Default Re: What oil in rear diff? (tshac)
where can i get amsoil? only through a dealer or are there retailer's around here like parts stores? im doing it tomm so i can t order it, unless i wait till next week. im changing out the tranny fluid an diff. if i go with reg. oil, anybody know the part number from chevy on the slip oil, or can i go aftermarket on that too?
Thanks,
Chan
Old Jan 23, 2003 | 07:49 PM
jimman's Avatar
jimman
I get flamed for recommending stock stuff but to risk all the good things in the C5 on Billy Bobs recommendations, not a chance. Darn metal just refuses to grow back. :rolleyes:
Old Jan 23, 2003 | 10:26 PM
Sam Lin's Avatar
Sam Lin
You can go aftermarket, most auto parts stores will have 75W90 gear oil, and limited slip additive in little tubes. Noone's proven any harm from NOT using factory GM fluids in this case.
Sam
Old Jan 23, 2003 | 10:31 PM
NastyC5's Avatar
NastyC5
Chan
If you want Amsoil email me for a good price :)
Old Jan 24, 2003 | 03:04 AM
whip383's Avatar
whip383
Default Re: What oil in rear diff? (NastyC5)
nasty, sent u an email.
chan
Old Jan 24, 2003 | 06:43 PM
carpe dm's Avatar
carpe dm
I have used both Amsoil 75W-90 and Mobil 1 (with GM additive), and I think both are excellent. GM did extensive research before coming up with their choice, so you can't go wrong with the stock synthetic either. Enjoy! :steering:
Old Jan 24, 2003 | 07:01 PM
Touringpro's Avatar
Touringpro
Thanks,
Chan
The P/N for GM Limited Slip Additive (4oz. bottle) is 1052358 - it'll run you around $6 or $7. Personally I use this in all my diffs along with Mobil1 75W-90 gear oil.
Old Jan 24, 2003 | 07:09 PM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Default Re: What oil in rear diff? (Touringpro)
I'm surprised RedLine hasn't been mentioned yet.... :confused: I thought that was the good stuff? :confused:
Old Jan 24, 2003 | 09:34 PM
HOTSOSS's Avatar
HOTSOSS
Default Re: What oil in rear diff? (Maineiac)
I'm changing mine out to Redline 75W90. It already has the limited slip additive in it. I emailed Redline and they gave me a list of dealers in my area. Otherwise you have to mail order. I'm changing to Redline because a few forum members say the differential runs quieter with it over stock stuff (I've got a slight noise at cruise), so for the cost of two quarts, I'm gonna give it a try. I'll post my results.
[Modified by BLU PIL, 9:35 PM 1/24/2003]
Old Jan 25, 2003 | 10:34 AM
gmblack3's Avatar
gmblack3
Default Re: What oil in rear diff? (BLU PIL)
http://www.woosch.com/tranny_diff_fluid_change.htm
Old Jan 26, 2003 | 12:39 AM
whip383's Avatar
whip383
Default Re: What oil in rear diff? (gmblack3)
hey, thanks for all the info. i cant believe all the help here with the corvette forum, couldnt do it without u.
thanks,
chan
its all done. :)
Old Jan 26, 2003 | 04:32 PM
vettenuts's Avatar
vettenuts
Amsoil here, very happy with it. Have also used Redline in the past. Be careful with the additive, best to call the tech line of the product you select as some won't mix with GM additive and some don't need it (Redline and Amsoil).
Also, love the color of your car :cheers:
Old Jan 26, 2003 | 11:29 PM
gmblack3's Avatar
gmblack3
Default Re: What oil in rear diff? (vettenuts)
I used the GM additive with the amsoil and had no problems.
Here is info that I found, Its on my "how to" from the link above:
Amsoil and Redline claim that there fluids already have an additive in them. Amsoil says it both ways on there website:
AMSOIL gear oils are formulated with friction modifiers for limited slip differential applications. There is no need to add limited slip or additional additives.
AMSOIL Series 2000 Synthetic Gear Lube provides limited slip performance. Although generally not necessary, original equipment manufacturers' limited slip additives may be used in conjunction with AMSOIL Series 2000 Synthetic Gear Lube.
Redline says:
LIMITED-SLIP COMPATIBILITY Red Line Gear Oils, with the exception of the 75W90NS, already contain friction modifier required for operation in limited-slip differentials. Additional additive is not required.
I have emailed Redline and asked them if it would not hurt to add the GM additive to Redline.
Here is the reply from redline
The 75W90 would be suitable for the limited slip in your Z06 it contains 5% friction modifier, typically what is needed to reduce the chatter from the limited slip when making a slow tight turn. Adding more friction modifier if it isn't needed reduces the lock up of the limited slip and reduces it's effectiveness, so I wouldn't add it unless it is needed due to chatter and then only just what is needed. The friction modifier isn't a lubricant but just an additive to make the fluid slipperier for chatter control. The 75W90 should be suitable right out of the bottle without the need for the additive. Thank you for your interest in Red Line Oil.
To What oil in rear diff?
