Harmonic balancer
Old Dec 10, 2023 | 04:37 PM
Brad401's Avatar
Brad401
Default Harmonic balancer
I'm putting a new ATI harmonic damper on My '01 convertible. I'm installing a ATI 917-266 which is aluminum not steel will this make a difference.
Old Dec 10, 2023 | 08:22 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
ATI is a widely used balancer, shouldn't be an issue.
Old Dec 10, 2023 | 08:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you are going to be doing balancer work, here are a few tips that I have found very handy:
Use a propane torch or a heat gun and heat the INNER HUB of the dampener that goes over the crank snout to aid in removal and reinstallation. Just heat it up to 200-225 degrees or so. It will come off and go on a WHOLE LOT EASIER!
The Autozone near me rents the dampener removal and install tool. They also rent the 0-150 FT/LB torque wrench if you dont have one.
I use the ARP Dampener Bolt. Its a no brainer verses the OEM Torque To Yield bolt that MUST be replaced after each use.
Make sure that you replace that nasty old hard front cover dampener seal.
Old Mar 29, 2024 | 11:20 AM
DWC4's Avatar
DWC4
Default should I do my own harmonic balancer repair or a shop?
I hope all is well with Mr. Bill Curlee, whose priceless tips and tricks on this forum have saved me tons of time and money - thank you sir!
Old Mar 29, 2024 | 11:51 AM
lucky131969's Avatar
lucky131969
Just remember the torque value varies based on if you use moly, loctite, or oil.
Old Mar 29, 2024 | 05:00 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Mar 29, 2024 | 05:01 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Were doing well. Now live in El Paso TX enjoying retirement.
To Harmonic balancer
