A-4 Shift Kits?
Old Jan 24, 2003 | 06:32 PM
50-50's Avatar
50-50
Default A-4 Shift Kits?
Any insight on shift kits for a 2003 C-5 4spd. Auto ???
Brands?, performance?, difficulties?
Or is it better to "edit" the stock?
Any input appreciated, Thanks... :cheers:
Old Jan 24, 2003 | 06:35 PM
hogurt's Avatar
hogurt
Default Re: A-4 Shift Kits? (50-50)
I just purchased the Transgo Shift kit. . .from what I have read on this forum, it's the way to go!
Old Jan 24, 2003 | 06:42 PM
50-50's Avatar
50-50
Default Re: A-4 Shift Kits? (hogurt)
Yeah, I was reading up on the Transgo.
Sounds like the hot ticket!
Good luck with your install. Are you doing it yourself or "by other"?
Thanks for the reply... :cheers:
[Modified by 50-50, 3:42 PM 1/24/2003]
Old Jan 24, 2003 | 06:47 PM
vstella's Avatar
vstella
It's the ONLY way to go!! :smash: :thumbs: More info herehttp://www.txchange.com/transgo.htm
Not only will you get crisper, durable and lightning quick shifts, you will be able to hold the gears longer and downshift at will.. Alot of fun! A whole new personality for your car. I would suggest that you get a programmer as well to delete the torque management system on the PCM program fop best results..but the Transgo will work without removal. The Transgo shift kit is the best bang for the buck low cost mod for the A4 out there....PERIOD! :thumbs:
To A-4 Shift Kits?
