a/c system
Old Jan 1, 2024 | 04:07 PM
Mitch45's Avatar
Mitch45
Default a/c system
In the spring I will have to replace the a/c compressor . I have avoided doing for the last 2 seasons , but the time has come . I am thinking of replacing the refrigerant lines at the same time . Has anyone else done this ? Any problems doing this ? Looking on Rockauto there are 2 seperate lines and not that expensive .
Old Jan 1, 2024 | 04:21 PM
jcgunn's Avatar
jcgunn
This is a job for professionals. The system needs to be evacuated first. You should also replace the evaporator and have the system flushed before re-filling.
Old Jan 1, 2024 | 04:52 PM
Trickskier's Avatar
Trickskier
Originally Posted by jcgunn
This is a job for professionals. The system needs to be evaculated first. You should also replace the evaporator and have the system flushed before re-filling.
Old Jan 1, 2024 | 05:18 PM
Mitch45's Avatar
Mitch45
I had a professional replace the compressor on my Chevy Blazer . He didn't put any oil in . burnt the compressor up . I'm not a professional but have installed several ac units in street rods and have had no problems . I will have the system evacuated before I take it a part . I only inquired here to see if anyone had any tips or tricks .
Old Jan 1, 2024 | 06:00 PM
redzg's Avatar
redzg
This link has an excellent reference document link embeded:
https://www.corvetteforum.com/forums...-write-up.html
Some of the additional links are long gone or broken, but the main link (http://c5.plus.beer/misc/C5%20AC%20C...eplacement.pdf) worked for me just a moment ago.
Old Jan 1, 2024 | 08:18 PM
Mitch45's Avatar
Mitch45
redzg , Thanks , even though I have done this on another vehicle . I downloaded this and will print it out . makes for a good reference to double check myself .
Old Jan 1, 2024 | 11:24 PM
bookyoh's Avatar
bookyoh
Here is a good service guideline document from AC Delco.
I am curious why you are considering replacing the lines. Are you thinking just the suction/discharge hose assembly or the all metal liquid line too?
Old Jan 2, 2024 | 12:57 AM
Moved to C5 Tech for discussion.
Old Jan 2, 2024 | 11:00 AM
grinder11's Avatar
grinder11
Replacing the evaporator is a Helluva job, and if you're paying a shop to do it, it's around $2,000-up!!! This is for just the evaporator and new actuators. The evap would be the last thing I would consider replacing. HOWEVER-anyone who has had a compressor fail internally, like a seizure, or other internal mechanical failure, should replace everything. The evap, condenser, compressor, accumulator, and lines.
Old Jan 3, 2024 | 04:52 PM
ncali's Avatar
ncali
I agree with Grinder, I would change the CONDENSER , not the evaporator. change the orifice tube and the dryer. Rock auto sells that kit.
The condenser will clog with compressor debris not the evap
Old Jan 3, 2024 | 07:53 PM
bookyoh's Avatar
bookyoh
Mitch45 has not explained why the compressor needs replacing. For example, mine has leakage from the body o-rings but no internal damage. If the compressor has not had a mechanical failure sending debris into the system, then an orifice tube, accumulator dehydrator, replace o-rings/seal washers, and an oil charge balance should be good for many years.
Old Jan 3, 2024 | 09:23 PM
Mitch45's Avatar
Mitch45
The compressor leaks . For the last several seasons I have had to have it charged .This past season I had to add 134 twice . Will probably just change the suction/discharge hose , but I plan or removing all the lines to inspect and replace the o-rings. Once I get the orifice tube out it will tell me the condition of the system and what further steps I need to take . And will replace the water pump since it will be off and fresh coolant .
Old Jan 4, 2024 | 05:54 PM
Midwest19942000's Avatar
Midwest19942000
Had the same thing on my 2000 Corvette. AC quit working and there was green compressor oil around the compressor housing where the housing O rings were leaking. I try to use Delco/Delphi parts but had a hard time finding an OE compressor and the online vendors that claimed to have them wanted $600. The only other options I saw seemed to be made in China. I ended up buying the compressor O ring kits from Auto Zone and had a local shop remove any remaining refrigerant. I then removed and disassembled the compressor and reassembled with new O rings. Took it back to a local shop for evac and recharge and worked great all last summer. I realize not everyone wants to go that far. I had never seen the inside of a compressor before and it wasn’t a difficult job with the help of others on this forum. All this to say I was determined not to give up the OE Delphi compressor that was made in Ohio.
Old Jan 4, 2024 | 11:22 PM
bookyoh's Avatar
bookyoh
That is great that you were able to successfully replace your body o-rings. I launch of that compressor back in 1996. Given all the work it takes to remove and install the compressor on a C5 I decided last year that I would not attempt to repair my weeping compressor so I searched and searched around until I found a Delphi service compressor for sale.
When I do get around to replacing it, I’ll give the new o-ring rebuild a try on the old leaky one and keep it on the shelf as a spare. I’m sure I’ll never find a Delphi replacement unit in another 20 years.
By the way, the V7 compressor for the Corvette was assembled in a Delphi Harrison/Daewoo Automotive joint venture plant in Korea. A few of the more critical components were manufactured in Moraine Ohio but the actual compressor assembly was in Korea.
Old Jan 5, 2024 | 11:54 AM
Midwest19942000
Yes Moraine OH is what it said on the compressor label. Interesting that it was assembled in Korea thanks for sharing. I couldn’t stomach tossing an otherwise good Delphi compressor over a few bad O rings. The car only has 27k miles on it and the compressor looked great on the inside. I’ll admit it is a lot of work and a little bit of a gamble for an amateur like me that everything is done right and it doesn’t leak after reinstalling. So far so good.
Old Mar 1, 2024 | 01:57 PM
dogboy's Avatar
dogboy
Any advice on how to get the condenser out. 2000 C5
Old Mar 1, 2024 | 02:13 PM
Davcruz's Avatar
Davcruz
Pull the radiator, the condenser is attached with some J-Hooks as I recall.
To a/c system
Old Mar 1, 2024 | 05:08 PM
Mitch45's Avatar
Mitch45
Had the ac system evacuated . I pulled the orifice tube . It doesn't appear to have any metal particles in it . Amazing there can be that much crap in a closed system .
Old Mar 1, 2024 | 05:13 PM
pjdbm's Avatar
pjdbm
Its not that bad to do.
You need to take off the radiator cover on top 4 bolts
Then you will need to take off the radiator shroud, not the whole radiator
The condenser sits on plastic clips, I sprayed them with WD before popping the condenser up and off the radiator.
Obviously disconnect the two Freon lines before doing so.
Old Mar 2, 2024 | 06:41 AM
dogboy's Avatar
dogboy
I got the two lines & the top shroud off. I have a Tranny cooler attached to the front of condenser that I need to remove with those plastic holders through the coils, what a PIA they are to remove. Once I get that off the condenser will slide up & off? It looks like it's not moving, Should I tap it up with a hammer? I have a new condenser so no care if the old one breaks just concerned that I don't break the radiator & the supports.
