O2 sensor failed AGAIN
Old Feb 20, 2024 | 07:27 AM
Gnomad's Avatar
Gnomad
Default O2 sensor failed AGAIN
Hi,
Have an ‘04 Z06 that spends most of its time on track doing hpde. This past weekend, p0155 code popped up AGAIN while at VIR. This same O2 sensor has died and been replaced 3 times already (in the past year) and am at a loss as what to do.
From reading here, my guess is the long tube headers are the likely culprit.
Couple questions…
Can anyone suggest a more permanent fix to try, rather than throwing O2 sensors at it?
What are the ramifications of ignoring it?
When the code throws at an event, I finish out the weekend and then have it replaced when I get home. However, this week I’m back on track in a couple days and my local shop can’t get me in in time, so I’m looking at two more days on track with the bad sensor. Am I hurting anything?
Any advice would be greatly appreciated! 😃
Old Feb 20, 2024 | 10:35 AM
Markolc1981's Avatar
Markolc1981
Your PCM will default to open loop if the O2 sensor is not working. That's not too big of a deal as long as your car has a good tune on it. FWIW your car runs in open loop whenever you're at WOT anyway.
Now as far as solution, is your car tuned for your mods? It's possible you're running super lean or rich with your mods and burning/fouling up your O2 sensor. I'm just throwing out guesses I know nothing about your car.
P0155 is the heater circuit of Bank 2 (passenger side of engine). Easy stuff is to check fuses and grounds. Next is to check the wiring haness, making sure it isn't pinched or burning up on your headers somewhere.
Wiring diagram here for '98 - Note your pinouts may be different, but fuses and grounds should be similar.
Old Feb 20, 2024 | 11:07 AM
grinder11's Avatar
grinder11
Not always LT headers. OP-Use only OEM GM O2 sensors. If you're running aftermarket this could be one reason.......
Old Feb 21, 2024 | 10:00 AM
Davcruz's Avatar
Davcruz
You can replace the passenger side yourself, it's the easy one with long tubes, driver side is a PITA. I just did both of mine, heater circuit failure.
Old Feb 22, 2024 | 06:27 AM
Gnomad's Avatar
Gnomad
Thanks for the replies! I only have cooling/reliabily mods and yes it’s been tuned. Cam/heads due to be installed in the next month or two, then a follow up tune. Someone suggested I mention the sensor problem and that the tuner could maybe do something? No clue what that’s about, but can’t hurt to mention it.
Going to go ahead and run at Road Atlanta this weekend, then back to the shop. Talked to the mechanic, he just did a swap of the OEM sensor last time. He’s going to spend more time next week trying to get at the root of the case.
Finally, glad to hear the passenger side is easier…was watching some YT videos, and man the drivers side looks difficult!
To O2 sensor failed AGAIN
