Replace Oil pump, or rebuild?
Old Mar 13, 2024 | 03:02 PM
Fast one's Avatar
Fast one
Last year I installed a Melling 10296 with the blue spring and the oil pressure is very good for a 130,000 mile engine, however it isn't raced. A Cloyes 9-3658TX3Z timing set was also used and it's tight compared to the sloppy factory chains. This guy has some interesting videos, this one is about oil pumps and pumping the pan dry.https://duckduckgo.com/?va=e&t=hq&q=...%3DUhqbBE8gzrM
Old Mar 13, 2024 | 03:49 PM
Smoken1's Avatar
Smoken1
I've been running the 10296 also, with the BTR chain damper and the elite chain for a couple years with no problems
https://www.corvetteforum.com/forums...-no-equal.html
Old Mar 13, 2024 | 03:54 PM
schmuckingham's Avatar
schmuckingham
I have used both. I have a mellling in the car now but when I did my cam swap I was lucky and had the pump already. At that time they where hard to find and I had my stock one sent out for porting. I still have it sitting wrapped up on the shelf.
I only had 42k on the clock though, in your case a whole new pump is not a bad idea.
