Vette-Lights front corner LED question....
Old Mar 18, 2024 | 11:03 AM
Z06Aaron's Avatar
Z06Aaron
Default Vette-Lights front corner LED question....
I need a sanity check. I started installing the Vette-Lights front corner assembly last night. I think there is a problem with the assembly but want to confirm what the function should be. When should the white led turn on if everything is functioning properly?
I started on the driver side. All the amber functions seem to be working properly, but the white led are not turning on. I've flipped the connector a couple times to see if it was a polarity issue and made sure I was seating the plug all way in. Either way, no white lite. I want to confirm before I disassemble the other side and see if that one works.
Old Mar 18, 2024 | 12:20 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
White LED should be on as the DRL, just as the old amber was.
Old Mar 18, 2024 | 12:24 PM
Z06Aaron's Avatar
Z06Aaron
That's what I thought. Shoot... looks like I have a bad assembly. Thanks for confirming!
Old Mar 18, 2024 | 03:12 PM
captain vette's Avatar
captain vette
I have these on my car freshly installed and they always lit when I start the engine
Old Mar 18, 2024 | 04:46 PM
jcgunn's Avatar
jcgunn
Try flipping the LED 180 degrees in the socket
Old Mar 18, 2024 | 06:02 PM
Z06Aaron's Avatar
Z06Aaron
Yep, tried that too many times figuring is was a polarity issue or maybe a corroded connection. Plugged in the pass side module, to the driver side, to verify operation and everything works as expected. Turns out It's just a bad module. Oh well. At least winter showed back up here in Michigan so I'm in no rush.
Old Mar 18, 2024 | 11:51 PM
03 Owner's Avatar
03 Owner
Try turning on the parking lights to see if they go white. I don't have vette lights but mine are white with parking I believe, could be wrong though haven't looked at it since November.
Old Mar 19, 2024 | 07:09 AM
Z06Aaron's Avatar
Z06Aaron
Default Update
There is something wrong with the driver side assembly. I did a bunch of troubleshooting last night. Contacted Cole at Vette-Lights and he is sending me a new Driver side lamp assembly. Great communication from him!
Old Mar 19, 2024 | 05:43 PM
BHauber's Avatar
BHauber
They turn white when parking light and or headlights on and yellow DRL when lights are off.
Old Mar 26, 2024 | 09:15 PM
Z06Aaron's Avatar
Z06Aaron
Everything is fixed! Cole at Vette-Lights sent me a replacement and everything is right in the world.
Old Mar 26, 2024 | 09:19 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Cole is great, I get all My led from @VetteLights
Old Mar 28, 2024 | 09:54 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Cole is the man. great service and i also get all my lighting upgrades from him
To Vette-Lights front corner LED question....
