Everything TPMS for the C5
This one should work fine
Anyone with stock of the OE parts will be selling very, very old sensors, likely at several times the price of the newer design sensors. The early C5 versions have been out of production for around a decade. The typical shelf life for these type of batteries is 13 years.
So far I have had zero luck training them with the Amazon 9 dollar gizmo or a large size common mechanics pen magnet. There is zero response. No honks.
In the event there is something wrong with these I do have my own tire equipment so it's not the end of the world, but certainly annoying for sure.
My next move is to find a stronger magnet? and then start somewhere other than the left front on the off chance that one is bad.
I was able to train them using a triangle welding magnet that I completely forgot that I had that was right in front of me in the garage the whole time!
They are still showing blank even after the honks but I'm sure that is because the car has not driven yet.
https://www.oreillyauto.com/detail/c...net/sch1/20143
I did not want to dick around this summer when I replaced all four corners on my 99. with Schrader 29178. Piece of cake.
I press options until the DIC goes blank then hold the option key down but it goes to something apart from key fob training immediately. I’ve been told this might be because the receiver module is not working. Would that be correct?
If so does someone have a part number and photos of the 2001 to 2004 receiver?
- These sensors need to be programmed before training the car, right? I'm pretty sure the answer is "yes" but I'm just making sure I fully understand.
- Discount Tire (the tire installer) says they are unable to supply sensors that work with the C5, citing a lengthy backorder.
- My friend purchased these Autel TPMS sensors. Discount Tire was unable to wirelessly program them and they apparently don't have a physical cradle.
Assuming yes, what I can tell you with certainty is that Autel sensors are junk. Save your money. Though I don't do this for a living, a good friend of mine does and I've never seen an Autel branded sensor (on the dirty floor of their shop) that had contacts for cradle programming. The same friend has also expressed to me that the Autel sensors tend to live about 4 years max before the battery sh#ts the bed.
Additionally, I would remark that likely the only reason the Discount Tire shop was unable to program them wirelessly is because the tool they were using was either incompatible or required an update. This is what you get with retail tire jockeys. The only thing they excel at is mounting and balancing 8 tires an hour on cars that are less than 10 years old. If you're really lucky they won't cross-thread your lug nuts in the process.
One last question - what trigger tool was being used during the training attempts (magnet or RF)?
This isn't rocket science. I've gone out of my way to try and help folks understand the underlying technologies. So forgive me if I seem confused and slightly annoyed when you go buying products that have never been mentioned here, and then ask why they don't work. Our cars are becoming antiques (my 2001 can be registered as an historic vehicle next year). Don't expect the snot-nosed punks jockeying tires to know anything beyond 15 years, because there aren't any gray-haired techs there to show them how to handle cars that were around before they were.
- My friend found a local tire guy who quickly and successfully programmed the sensors with a wireless device and then successfully paired them with the C5.
- When I asked what the tire guy did differently than Discount Tire, my friend replied "Probably, he read the instructions."
- The sensors are presently mounted in new Forgestar F14's and shod in new ECS02's.
He bought the Autel sensors because he was in a hurry. You and I might have waited a few more days for parts to be delivered; he chose differently.
We noted the availability of TPMS on this car shortly after he acquired it.
1. My friend hasn't kept any car for four years. He likes to wheel and deal.
2. If he actually keeps this car for four years, it's *highly* unlikely that the tires will last that long.
He'll have opportunity to replace the Autel sensors if desired, when he has more tires installed.I'll let my friend know he's a pioneer!
Perhaps I can help with the confusion and frustration. For the record, I didn't ask why they don't work. I asked if I understood the process correctly; you affirmed that I do, and I thank you. I also asked if anybody had used these successfully, and if yes, what steps they followed. I wish I had witnessed the shop's actions so I could help others by providing the steps. As Woody Hayes used to say, "Pay it forward."
As I'm typing this I'm about to go mount 4 new skins on my mom's Nissan. I will be using the SmartSensor programming tool to clone the original (circa 2009) sensors so no relearning is required. The point I'm trying to make is if you know people with C5s (particularly early models), and also have other vehicles with TPMS, the SmartSensor tool will pay for itself. Additionally, maybe you could setup a TPMS "lemonade stand" near Discount Tire stores and possibly produce additional hustle as it will also program most sensors wirelessly.
https://a-premium.com/product/2001-2...nsor-aptpms312
These sensors are supposedly pre-programed and guaranteed to work with the 2001-2004 C5.
Discount Tire installed the sensors for $10 per wheel (since I had purchased the tire there. $20 if not) and we were able to get them to learn through the DIC procedure with their tool. I had tried the magnet learn procedure and that did not work with these, so not sure if that is not a thing anymore or if just these sensors don't have that functionality. I've only had them in place for a few days, but so far they appear to be working fine and I am no longer getting the TPMS system error on startup.
Just thought I would throw this out there since this thread had helped me out with my purchasing decision.
https://fccid.io/2AEIM-1472547G
