Compressor location not optimal
Old Jul 2, 2024 | 03:26 PM
tookielee's Avatar
tookielee
I understand you... but I'm not sure why my engine is now running about 30° cooler now than before the change.
Max temp is still the same, but cruising with or without A/C much lower. I cleaned a little debris from radiator fins,
but not THAT much.
Old Jul 2, 2024 | 06:17 PM
bookyoh's Avatar
bookyoh
but not THAT much.
I suspect that if you start your car, let it idle, and hold the upper radiator hose as it warms up, you will find the hose gets hot well before your 187 degree thermostat.
Old Jul 2, 2024 | 08:32 PM
tookielee's Avatar
tookielee
No doubt. I guess it doesn't matter, but i'd be interested in knowing WHY it's
running 30° cooler than before. Mysteries bug me
