2nd gear problem
Old Apr 17, 2024 | 07:13 AM
Rocky_LS6's Avatar
Rocky_LS6
Default 2nd gear problem
So I just got my 03 zo6 about 2 weeks ago and somthing I noticed is that when ur downshifting
1 and 2nd gear is locked I do have a Gold mgw short throw But I was wondering if mabey it’s the Skip shift doing that? And some times 2nd gear even grinds with they clutch fully to the floor!? Not sure what it is my geuss is the skip shift 1-4 the only time 2nd will grind is when ur going slow speeds But normal driving it will not thank u guys.
Old Apr 17, 2024 | 07:23 AM
Moved to C5 Tech.
Old Apr 17, 2024 | 04:59 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
The skip-shift function forces a 1-4 upshift (not downshifting) under light load conditions. What does "1 and 2nd gear is locked" mean? Have you tried adjusting the "Gold mgw short throw" shifter?
Old Apr 18, 2024 | 01:22 AM
Rocky_LS6's Avatar
Rocky_LS6
I haven’t all I know is this shifter was in the car when I bought it and When I was coming home with the car I was trying to go from 4th to 2nd gear to pull in to my neighborhood and It would go in 2nd it was like it was locked and it was making a roaring noise kind of?!
Old Apr 18, 2024 | 04:38 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
I have no clue what could be causing your "roaring noise." You may want to check the fluid level in your transmission. BTW, the transmission is in the rear of the car bolted to the axle housing. The car has to be sufficiently elevated and level in order to check the fluid level. Good luck with your troubleshooting efforts.
To 2nd gear problem
