Cough, cough...burp!
Old Jan 30, 2003 | 09:05 AM
bierbelly's Avatar
bierbelly
Default Cough, cough...burp!
OK, was driving my Vette home in the snow yesterday. Got caught out by surprise...the weatherman lied! :mad Anyway, it was a little slippery, of course, and the trac control was on and off. Some places I had to start off in 2d gear...you know the story.
So when I'm stopped at lights, I notice the engine's missing, running rough. Even at relatively low rpm in gear, say up to about 2K. So my question is, was the car just asking me "WTF is this crap, you take me out in the snow?" or is this a common problem? :confused:
Old Jan 30, 2003 | 09:29 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: Cough, cough...burp! (bierbelly)
A couple of questions for you. What air intake do you have. If it's a bottom breather or open shroud intake, my next question is, did the air dam happen to scrape up any snow.
If not, do you have a silicone cooupler between the air bridge and the throttle body. If so, I'd check to see if it collapsed underneath. Cold does make things contract, especially rubber.
These are the only things I can think of right of the top of my head.
Old Jan 30, 2003 | 09:54 AM
bierbelly's Avatar
bierbelly
Default Re: Cough, cough...burp! (CorvetteSS)
Bone stock, from front to back. Has about 25K on it now. Air filter dirty? About when should they be changed, under typical driving conditions? (This ain't Texas; we don't have dust storms here).
pburant's Avatar
pburant
Do you have the throttle body coolant bypass? That could be the culprit. The reason GM runs coolant thru the throttle body is to prevent icing problems in cold weather.
If you don't have the bypass, I don't think I can help you.
Good luck - I hope it's an easy fix!
*EDIT* - didn't see your second post before I replied. Hopefully you get to the bottom of this quickly.
[Modified by pburant, 9:56 AM 1/30/2003]
Old Jan 30, 2003 | 08:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bier
Check for any stored codes. See if you have any that deal with the MAF! If you do then maybe some of us can figure it out!
Man I love it when a plan comes together!!! :thumbs:
Bill C
Old Jan 30, 2003 | 08:18 PM
Darrell G's Avatar
Darrell G
Default Re: Cough, cough...burp! (Bill Curlee)
OK bierbelly, i heard that comment about Texas. I will have you to know we love our dirt, even when it's from out of state. :)
Old Jan 31, 2003 | 01:30 PM
bierbelly's Avatar
bierbelly
Default Re: Cough, cough...burp! (Darrell G)
Hey, I wasn't crackin on Texas. When I crack on Texas, it's much worse than that! :D
No, I was just wondering what the average lifespan of the stock air filter was (and noticed that corvettess was from Tx). Stupid of me really, who else on this site has actually kept their air filter stock until it needed to be replaced... :rolleyes:
Old Jan 31, 2003 | 10:55 PM
AllCammedUp's Avatar
AllCammedUp
The word stock is not in my vocabulary. :lol:
Seriously, you probably have a sensor that is loose, or you have some unmetered air getting through due to one of the reasons mentioned above.
Old Feb 1, 2003 | 12:06 PM
bierbelly's Avatar
bierbelly
Default Re: Cough, cough...burp! (AllCammedUp)
Good news! Problem solved. Loose spark plug wire on the right front plug (good thing I could reach it). DOH! :grouphug: Thanks for the input.
To Cough, cough...burp!
