Upper column shaft
Old May 3, 2024 | 07:58 PM
Daws's Avatar
Daws
Default Upper steering column shaft
Hey everyone! I was wondering if anybody has ever replaced just the upper portion of the steering column. I came across this yesterday when I removed the steering wheel and was originally going to just replace the whole assembly but saw that I can just buy the upper portion. Thanks!
Old May 3, 2024 | 10:27 PM
USAZR1's Avatar
USAZR1
This belongs in C5 Tech.
Old May 3, 2024 | 11:02 PM
Daws's Avatar
Daws
okay thanks!
Old May 3, 2024 | 11:27 PM
link9a's Avatar
link9a
Yes.. you can just replace the upper column shaft .. very easy .. you can buy it from eBay
Old May 3, 2024 | 11:30 PM
Daws's Avatar
Daws
Originally Posted by CorvetteHeadz
If you google upper shaft a bunch of options to buy.
yea I had seen some but couldn’t find anybody replacing it so was trying to make sure it was actually possible haha thank you!
Old May 3, 2024 | 11:31 PM
Daws's Avatar
Daws
thank you for confirming! Gonna try and see how I can dissemble it this weekend
Old May 3, 2024 | 11:33 PM
link9a's Avatar
link9a
Old May 4, 2024 | 12:53 AM
Daws's Avatar
Daws
Was it just a couple of bolts?
Old May 4, 2024 | 10:52 AM
link9a's Avatar
link9a
Mark the clock spring so you don't turn it over when you put it back
remove that washer
Using special tools to release the pressure to remove the ring
Remove the ring
Than remove the plate and the plastic piece
Remove HEADLIGHT / TURN SIGNAL / CRUISE CONTROL LEVER bolt's (2003 Auto US build don't have Steering Wheel Lock)
Release that spring by pushing down screwdriver
Remove that PIN from the both side by finding a screw Allen key . You need to take out that PIN by tightening the screw in
Remove the bracket after the that
All done
Old May 4, 2024 | 01:58 PM
Daws's Avatar
Daws
damn!! Thank you so much for this, which specialty tool did you use to remove the ring?
Old May 4, 2024 | 02:18 PM
link9a's Avatar
link9a
I forget the name for the tool.. show the picture to the auto parts and they will give you one
Old May 4, 2024 | 02:20 PM
Daws's Avatar
Daws
You’re the best! I really can’t thank you enough. I ordered the parts so hopefully I can get back up and running by next week.
Old May 4, 2024 | 02:28 PM
link9a's Avatar
link9a
You welcome ...did you buy the column shaft complete piece like this one with the ball ?
Old May 4, 2024 | 02:34 PM
Daws's Avatar
Daws
yes! After you sent that first picture of it I made sure to find one with the ball.
Old May 4, 2024 | 02:39 PM
link9a's Avatar
link9a
That good because the ball are removable from shaft to other shaft if needed. and it's very complicated if somebody missed the original direction when he put it because the shaft doesn't fit as before ...
Make sure to take some pictures or video when you remove the original shaft in case of you forget how you put back the shaft
To Upper column shaft
