What temp
Old Jun 25, 2024 | 10:32 AM
Mike252's Avatar
Mike252
4th Gear
Default What temp
What temp should a c5 run in town when it’s 80° outside. Seems to run at 190/220 what I observe! Is that something I need to be concerned with? I’d like to take a ride to Maine but a little hesitant! 8 hour ride! Or more depending on NY CT and Mass traffic !!
Old Jun 25, 2024 | 11:34 AM
jcgunn's Avatar
jcgunn
192 on the road, 200 at a long light, 220 in the drive thru
Old Jun 25, 2024 | 11:36 AM
Dads2kconvertible's Avatar
Dads2kconvertible
190/220 is a fine temperature Mike. Here in Texas 100 degree day heavy traffic I hit 230 from time to time. You're fine.
If you're exceptionally concerned you can make sure you have the later 18lb coolant tank cap instead of the earlier 15lb cap. That will raise your boiling point a few more degrees.
Running the AC will force both fans on, that should also help keep temps a little lower for a little longer. But the fans come on in the manner they were programmed before you get to 230 anyway.
Old Jun 25, 2024 | 01:03 PM
Mike252's Avatar
Mike252
4th Gear
Default My first Vette
Spoiler
Old Jun 25, 2024 | 02:35 PM
Dads2kconvertible
Air will not turn off just because your top is down, something else going on there.
Sounds like your temps are fine to me.
Might be worth looking at the front side of the radiator and cleaning out any debris that might be partially blocking it. These cars are very low on the road and get air from the bottom so it's not unusual to have some leaves built up there. Run the front tires up on a couple 2x6 so you have a little room to work.
Old Jun 25, 2024 | 02:48 PM
Mike252's Avatar
Mike252
4th Gear
Default Thanks
Spoiler
Old Jun 25, 2024 | 04:52 PM
Mike252's Avatar
Mike252
4th Gear
Default Some debris
[QUOTE=Mike252;1607931162]
Spoiler
there was some debris in the top edge on both sides but not sure if it would affect too much but I did blow it out of there so I’ll play with it more tomorrow and see how things go. Just love cruising around maybe I’ll try it with the top up lol … thanks again!
Old Jun 26, 2024 | 02:11 AM
wrmiles's Avatar
wrmiles
Other problems I have had:
Fan motor failure
Fan control relay failure
Radiator just plain dirty.
Long uphill in Death Valley on a real hot day
Old Jun 26, 2024 | 11:40 PM
vette4fl's Avatar
vette4fl
[QUOTE=Mike252;1607931484]
Originally Posted by Mike252
Spoiler
It’s amazing how much the junk in the condenser and radiator affect cooling. Well, duh, right? It’s just that these cars are very susceptible to debris. Every time we drive over grass cuttings blown into the street, we’re taking some home…. Even on a 90°+ day in Florida my engine coolant rarely goes above 205°. If you’re going from the gauge, it might read higher. Use you “Gauges” button on your DIC screen to coolant temp and it will be more accurate and precise.
To clean the condenser properly it is a chore removing the air cleaner and radiator cowl from the front. But that’s the best way for a thorough cleaning.
Next best is removing the cover above the radiator and using air and water wands.
Radiator Genie - Water & Air Cleaning Wands for High Efficiency Cooling Systems and Radiators - Blow Out / Wash Out Kit https://a.co/d/06b0R2oP
Oh, and to reference a post, just click the Quote button on the bottom of a post 👍
To What temp
