Reduced Power problem
Old Jul 11, 2024 | 02:53 PM
thefuzz74's Avatar
thefuzz74
8th Gear
Default Reduced Power problem
I. bought this car a month ago, it's a 1997 c5. Previous owner trashed it, so I've been working on it. I've replaced aot.of stuff that was tore up or not working. One problem I keep having is " reduced power". It throws no codes at all. As soon as it happens I check and no codes. If I turn off traction control it runs fine and I can drive it for hours and hours. If I turn it back on, it may run good for an hour or may go straight into reduced power. I cleaned and checked all grounds. Wires look great. I've checked tac module, tps sensor. I'm just dumbfounded. Any ideas? Thanks in advance.
