Cracking noise when rolling from a stop and breaking
Old Aug 4, 2024 | 07:19 PM
Jpc5sliver's Avatar
Jpc5sliver
7th Gear
Default Cracking noise when rolling from a stop and breaking
My car has been making a noise when rolling from a stop and breaking I can't seem to figure out what is causing it
Old Aug 4, 2024 | 09:38 PM
douglasjre's Avatar
douglasjre
Use a pry bar to test them ball joints and get back to us with your results
Old Aug 5, 2024 | 01:53 PM
Jpc5sliver's Avatar
Jpc5sliver
7th Gear
got under it all the joints are good and i believe the suspect was my cv half shaft is bad as it had leaking grease on it and the wheel i will replace my cv's and see if my problem is gone
Old Aug 5, 2024 | 08:20 PM
Moved to C5 Tech.
Old Aug 20, 2024 | 09:37 PM
douglasjre's Avatar
douglasjre
Would u mind closing the loop with the results?
To Cracking noise when rolling from a stop and breaking
