Dashboard lights flashing
Old Aug 6, 2024 | 03:08 PM
PapB's Avatar
PapB
8th Gear
Default Dashboard lights flashing
Dashboard lit up like a Christmas tree
SUspect it is grounding issue
Have cleaned grounding boxes on driver's side
Cleaned passenger side also, lights stayed off for 2 hours of travel and then started again
Suggestions?
Old Aug 6, 2024 | 05:00 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Check the battery?
Old Aug 7, 2024 | 05:29 PM
Moved to C5 Tech for answers.
Old Aug 7, 2024 | 08:28 PM
TheBac's Avatar
TheBac
Could be a comms issue with one of the modules. Check for codes using the car's diagnostics. If one of the modules reads "No Comm" then thats where you start.
Could be a fuse to the module is bad, or the wiring connectors arent making good contact.
To Dashboard lights flashing
