Alternator Interchangeable?
Old Sep 14, 2024 | 10:06 AM
Timmeh053's Avatar
Timmeh053
Cruising
Default Alternator Interchangeable?
Still stuck on replacing my 2002 Manual Coupe alternator, 90% sure it is the alternator.
I've done some reading and I'm curious if anyone would know if the 01-02 Automatic Alternator #10316182 would work with a manual that normally came with #10246634.
From what I understand based on this post https://www.corvetteforum.com/forums...nd-issues.html
The alternators are almost identical except the auto's had a decoupler on them to improve efficiency and lifetime of the part.
Would this one work properly on a manual without giving a charge system fault?
Old Sep 14, 2024 | 11:39 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Wouldn’t change it unless you are 100% sure !!
Old Sep 16, 2024 | 10:20 AM
Bobbo76's Avatar
Bobbo76
Veteran: Canadian Forces
I'm on my second season with "this" alternator. I occasionally get a charge system fault. Press reset and carry on. I really like having the decoupler for my supercharged set up as it theoretically reduces belt whip.
Powermaster 58969 Powermaster High-Amp Alternators | Summit Racing
Old Sep 17, 2024 | 03:21 AM
Timmeh053's Avatar
Timmeh053
Cruising
When the fault appears everything still running fine? Volts in normal range and whatnot?
Old Sep 17, 2024 | 08:14 AM
Bobbo76's Avatar
Bobbo76
It's been about 2 years of use and I've never had a single issue. My GUESS is it sees higher than normal current on start up which is why theres a "charge system fault" and then clears. It's a 220 amp alternator so much higher than oem. I do everything with the car so it's certainly been put through the ringer.
To Alternator Interchangeable?
