Hazard lights hyperflash
Old Oct 26, 2024 | 06:22 PM
CEZ's Avatar
CEZ
Default Hazard lights hyperflash
A while ago i installed LED bulbs in my tailgate’s with hyperflash hraness and every thing was flashing as they should. Tonight I installed LED front turn signal bulbs left and right signal flashing as they should, but I get a hyperflash when I use the hazard lights am I missing something here?
Old Oct 27, 2024 | 01:02 AM
Moved to C5 Tech for assistance.
Old Oct 27, 2024 | 10:29 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
That, unfortunately, is one of the "hazards" 😁 of using LED bulbs. Mine does it too but I never use them anyway. So it doesn't bother me to much. I've never looked into fixing it either.
Old Oct 27, 2024 | 10:50 AM
Mark Romans's Avatar
Mark Romans
2nd Gear
Put a resistor across the Center High Mounted Stop light.
Old Oct 31, 2024 | 01:09 PM
lionelhutz's Avatar
lionelhutz
Hyperflash harness only does the turn signals. The hazards and switched onto the flasher all internally inside the switch so it'd require circuit board modifications to fix.
Old Oct 31, 2024 | 02:30 PM
CEZ's Avatar
CEZ
I think I got the fix for it is to use Morimoto bulbs they come with built in resistors they are anti hyperflash. I am going to order two sets for the taillights and report back.
Old Oct 31, 2024 | 07:55 PM
link9a's Avatar
link9a
The voltage get drop in the circuit line ..try to add resistor to the third brake line and see ..
Old Nov 1, 2024 | 02:52 PM
CEZ's Avatar
CEZ
https://youtu.be/n91q-U_mSLM?si=uaKXVftBDTYxaCsT
I don’t get any errors just a hyperflash with hazard lights.
Old Nov 1, 2024 | 06:48 PM
epimetheus-lee's Avatar
epimetheus-lee
Turn signals and hazard use two different 'flashers'. DOT safety regulation from the late 1960's. LED Hyperflash kit bypasses the OEM 'flasher' for the turn signals only.
Old Nov 1, 2024 | 10:29 PM
BRKLYN's Avatar
BRKLYN
I installed LEDs front switchbacks and regular in rear. At first lots of hyper flash. I came on forum and I learned if I four way flashed for a minute and shut off bikes, light bulbs would be ok. Mine is 01 Ultra Classic
disreguard wrong forum lol
Old Nov 6, 2024 | 04:59 PM
lionelhutz's Avatar
lionelhutz
It doesn't, both hazards and turn signals use the same flasher circuit in the hazard switch.
Old Nov 24, 2024 | 09:16 PM
CFight's Avatar
CFight
My hyperflash harness awaiting install has a removable flasher on it. When a motorcycle had hyperflash I bought a couple adjustable flashers that can be set to whatever rate you want. Haven't tried them together yet but I assume they'd work. https://www.ebay.com/sch/i.html?_fro...c&LH_PrefLoc=3
To Hazard lights hyperflash
