Z06 PCV System
Old Feb 6, 2003 | 10:51 AM
marco383's Avatar
marco383
Default Z06 PCV System
The final solution to my oil in the intake tract problem appears to be converting to the late Z06-style PCV setup. Two questions: what parts do I need, and will the Z06 valley cover fit on my C5R block ( I realize that it won't work on the LS1 block without machining).
Old Feb 6, 2003 | 09:08 PM
Teddy98Z28M6's Avatar
Teddy98Z28M6
Default Re: Z06 PCV System (marco383)
1) You will need the LS6 intake valley cover and the LS6 pcv pipe.
2) The older LS1 blocks had a extra casting area which gets in the way of that LS6 oil catcher, which is underneath the intake valley cover. We used a dremel and hack saw to cut the area. It wasn't too hard.
I can send you some pictures from my install on my '98 LS1 block.
[Modified by Teddy98Z28M6, 8:33 PM 2/6/2003]
Old Feb 7, 2003 | 05:31 AM
marco383's Avatar
marco383
Default Re: Z06 PCV System (Teddy98Z28M6)
Thanks Teddy. You are the man!
To Z06 PCV System
