Headlight not going up
Old Nov 21, 2024 | 06:08 PM
Yellowc5z0666's Avatar
Yellowc5z0666
2nd Gear
Default Headlight not going up
My left headlight wont go up but can be lifted up, the right one goes up but cant be lifted. I tried holding it up and turning the switch on and it didnt work. The little motor spins when the headlight switch is used but the left side spins by hand very easily and the right one is tight and takes a little force to turn the wheel. Is this a headlight motor issue?
Old Nov 21, 2024 | 07:50 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Default have you checked gears
The head light motors have a plastic gear and some times they can strip the teath. If you here the motor, but nothing is happening,, check worn or bag gear.
