clutch.......
Old Nov 22, 2024 | 09:16 AM
clutch1's Avatar
clutch1
Default clutch.......
how much horse power will a LS7 clutch, handle?..1999, frc....Thanks...........
Old Nov 22, 2024 | 09:34 AM
lucky131969's Avatar
lucky131969
I feel like this is a trick question. It is designed to support the output of the LS7 engine, so google that for your answer. If you want room to grow, choose an aftermarket clutch.
Old Nov 22, 2024 | 10:08 AM
Corvette Don's Avatar
Corvette Don
These are WELL known for handling 600WHP with ease, they will NOT do good on drag radials launching repeatedly at the track. I have one in my 2000 FRC with a cammed LS3 (525 flywheel hp) with a tick master and it drives like stock. I spent about $350 on the clutch and flywheel. I have went the aftermarket clutch route in the past and it was not a good experience. Heavy pedal, expensive, release issues, etc. Even if/when my LS7 clutch dies, ill definitely get another one.
Old Nov 22, 2024 | 10:46 AM
clutch1's Avatar
clutch1
Thank you..... looking to put a pro charger on..The first shop said no, it will kill the clutch...clutch is 2 years old.......
Old Nov 22, 2024 | 10:55 AM
lucky131969
I went with Textralia OZ700 when I did my Vortech. I'm at 530HP/500 lb ft TQ. It's been a great clutch as a driver and the strip. Just remember, everything you make stronger up front finds the weak link as the power transfers to the wheels. Plan on going through the torque tube. I also swapped out my differential with an RPM stage 3 unit with a 3.73. ......and a good set of drag radials.
Old Nov 22, 2024 | 09:03 PM
Corvette Don
Yeah, for your case, I wouldn’t go with a LS7
Old Nov 22, 2024 | 10:55 PM
vette4fl's Avatar
vette4fl
Depends on how you drive it. If you’re dumping the clutch for a burnout, then the LS7 is not the top choice.
To clutch.......
