What I mean by threads breaking into the intake ports is pretty simple. The threaded/tapped holes that mount the rocker arms are tapped to a specific depth. When the ports are enlarged while porting them the ports can actually break into/expose the rocker hold down threads. The threads would then be exposed to vacuum. Lots of oil up by the rockers. When exposed to vacuum oil can be sucked into the ports and drawn into the combustion chamber.......
I see, and you think this is the more likely cause than the valve stem seals? Is there anyway for me to to tell when I open it up tomorrow?
After you remove the intake manifold, which, by the way, doesn't look anything like an OE manifold, based on the video that you posted, you can look down into the intake ports, and if the rocker stand bolt holes are exposed, you'll be able to see them. What you should see, is an uninterrupted, relatively smooth surface. Any deviations, especially ones that are at the "top surface" of the port, would be indications that the valve train bolt holes have "broken through"....
Well I tried removing the valve springs today, first my 8mm socket snapped loosening the rocker bolts - so I had to go out and buy a new one. Then my spring compressor tool managed to cross thread so it's barely usable and then when I finally compressed my first spring the keeper launched sky high and will never be seen again.
I rotated the the crankshaft so the cylinder im working on is TDC so the valves can't fall more than an inch or two.
I use a borescope to make sure the cylinder is at the top. I felt so prepped for this job and its failed fantastically. Being in the UK the parts I need likely won't arrive until after Christmas.
Ok good. If you started with #1, you can do #6 at the same time, turn crank 90 degrees and do #5 and #8, turn crank 90 degrees and do #4 and #7, turn crank 90 degrees and do #2 and #3.
You just addressed a question that was in the back of my mind. I was suspecting that you weren't located in the US.
"LS2 Ported Heads" doesn't mean much.
Look at these images of LS2 ported heads. Do you see any red ones?
Maybe it's just me but I like to be sure the replacement parts are going to fit BEFORE I start the job. It annoys me to take the thing apart only to find out I have to order new parts because what was supposed to fit, didn't.
You don't suppose that the simplest explanation is often the correct one?
Stock LS2 heads (799) ported and painted red by the previous owner? lmao. Such a hard concept to grasp. Jesus
I am not enjoying this mechanic work so far.
Those M8-1.25 rocker bolts can be bitchy to loosen sometimes. I use a 6 point impact socket. Several years ago my wife was in the garage doing something when I broke one loose with a resounding "CRACK." She jumped and said man, what was THAT?? She thought I broke something.
I was using a small ratchet with a tiny little adapter on it and it snapped on the first bolt. Went out and got a chunky 3/8" to 8mm socket for my bigger ratchet and that was much better.
