Predator Load Problems
Old Feb 9, 2003 | 06:47 AM
cthoreen's Avatar
cthoreen
Default Predator Load Problems
I tried to load the Predator Performance Tune today and got a script error? VVVVVVVVEEEEEERRRRRRYYYY SCARY!!!!!!!!!!! So I reloaded the stock program and it took it just fine. Needless to say I'm back to square one. From what I've read here on different posts you need the version 1.03 with an A4 car which I have. Any ideas?
Old Feb 9, 2003 | 09:27 AM
1SGRET's Avatar
1SGRET
St. Jude Donor '12-'13
Default Re: Predator Load Problems (cthoreen)
Reload. Be sure to follow instructions. Apply parking brake. Turn off all accessories. Good luck! :cheers:
Old Feb 9, 2003 | 11:15 AM
Killrwheels's Avatar
Killrwheels
Default Re: Predator Load Problems (1SGRET)
When I first tried it I got an error, and none of the dash would work. I reloaded as James asked, and everything went well. Since then, I have loaded/reloaded many times and never a problem. Try again.....
Old Feb 9, 2003 | 03:30 PM
MagRedSkull's Avatar
MagRedSkull
:withstupid:
Also recommend you get it upgraded to the latest version.
Old Feb 9, 2003 | 07:54 PM
esram's Avatar
esram
Default Re: Predator Load Problems (MagRedSkull)
I thought 1.03 was the latest version. Isnt it? :(
Old Feb 9, 2003 | 10:49 PM
cthoreen's Avatar
cthoreen
Thanks for the advice and encouragement. It worked the second time. I'm pretty sure it was the twilight sentinal which I hadn't turned off. I had also heard that vesion 1.03 was the latest. One thing I noticed in the instructions was that you can modify something to do with the rear end ratio but not on an '03. anyone know anything about that?
Old Feb 9, 2003 | 10:55 PM
Maverick's Avatar
Maverick
Default Re: Predator Load Problems (esram)
It is the latest version
Old Feb 9, 2003 | 10:59 PM
Maverick's Avatar
Maverick
Default Re: Predator Load Problems (Killrwheels)
The instruction did indicated, you will see all sorts of error when loading, and it specifically said, "Do Not Be Alarm". I hope you didn't try and stop the programming at that time.
Old Feb 9, 2003 | 11:10 PM
cthoreen's Avatar
cthoreen
Default Re: Predator Load Problems (Maverick)
No it gave me a script error and then rudely kicked me out. :eek:
Old Feb 9, 2003 | 11:23 PM
Maverick's Avatar
Maverick
WOW, thats scarry! Try this steps:
- Get in Car
- Close Door
- Plug in Preadator
- Turn Key to On Position
- Follow the screen. :D :D
I don't know what to tell ya. The instruction seems pretty easy enough to follow.
If you followed every steps accordingly, you may have an defective unit.
Good luck to you CTHOREEN.
Mav
Old Feb 9, 2003 | 11:31 PM
cthoreen's Avatar
cthoreen
Read my other post up there a ways. I finally got it to take the performance tuneup on the second try although it took me another day to work up the courage to try it again. :D
To Predator Load Problems
