Passenger Side Window Motor Connector
Old Jan 13, 2025 | 01:01 AM
kmartinka's Avatar
kmartinka
Default Passenger Side Window Motor Connector
I am working on my 2004 Chevy Corvette replacing a passenger side window regulator assembly. I am using Dorman 748-473. Unfortunately, I have the 2nd design motor pigtail(PT2072) on my harness and Dorman's motor has the first design(same as driver side). Does anyone know where I can get an adapter harness/connector?
Old Jan 13, 2025 | 01:44 PM
kmartinka's Avatar
kmartinka
I purchased a NOS OEM regulator with the proper connector. I will be returning the Dorman regulator. I also informed them they should include an adapter in future kits. No thanks to GM for changing the design without future support.
Old Jan 13, 2025 | 06:07 PM
vetrnz06's Avatar
vetrnz06
Where did you purchase the OEM regulator? TIA
Old Jan 13, 2025 | 06:30 PM
kmartinka's Avatar
kmartinka
Got lucky and found 1 on Ebay. NOS.
Old Jan 13, 2025 | 06:33 PM
lucky131969's Avatar
lucky131969
If this experience triggered you.........you have a long road ahead of you partner. This is a late change in the run think it started surfacing about 10 years ago....,but it will not be the last unique item you find on that 2004. You dodged a bullet, because Dorman is mosty crap anyway.
Stay away from Amazon
Stay away from ebay motors (unless you can find a 100% seller with the exact p/n you need).
Take pictures before you order, so you know what your end looks like.....and research.
Old Jan 13, 2025 | 06:46 PM
lucky131969
14 years ago. How time flies.
https://www.corvetteforum.com/forums...fferences.html
Old Jan 13, 2025 | 06:57 PM
kmartinka's Avatar
kmartinka
I know what you mean. Nothing surprises me with GM. Some of the crap I seen at the Bowling Green and Fairfax Assembly plants was amazing. I do like their product and have been buying their cars for 30 years.
Dorman can be a hit or miss. Dorman does design some of their products, but they source a lot of their products as well. All the aftermarket window regulators are probably sourced from the same manufacture; they all look exactly the same. We should be thankful they still make parts for Corvettes.
Old Jan 13, 2025 | 07:01 PM
kmartinka's Avatar
kmartinka
I think I should okay with this.
https://www.ebay.com/itm/315602232893
Old Jan 13, 2025 | 07:10 PM
lucky131969
Great find! That p/n also agrees with the thread from 14 years ago.
Old Jan 13, 2025 | 07:17 PM
kmartinka's Avatar
kmartinka
Thanks. As mentioned, I got lucky.
I used https://parts-catalog.acdelco.com to look up the part number. They "usually" have the latest part numbers listed.
Old Jan 13, 2025 | 07:19 PM
lucky131969
Yup...got that bookmarked
Old Jan 19, 2025 | 02:34 PM
kmartinka's Avatar
kmartinka
This Ebay seller has 1 left for whoever needs it. I got mine!
To Passenger Side Window Motor Connector
