Service column lock message
Old Jan 13, 2025 | 10:39 AM
TPacifica's Avatar
TPacifica
Default Service column lock message
Dear Members:
Does anybody have a link to instructions on how to clear service column lock message from display? I installed the bypass several years ago and appears to be working. The battery died recently and after I charged it and started the car this message keeps coming up and I cant get it to clear.I can find plenty of videos on how to install the bypass but I can't find anything to just clear out the warning message.
Todd
Old Jan 13, 2025 | 11:26 AM
Moved to C5 Tech.
Old Jan 13, 2025 | 12:05 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A bad battery can sometimes cause this…if your battery died and not knowing what was the cause I’d have your battery load tested and then replaced if bad.
Old Jan 13, 2025 | 12:12 PM
lucky131969's Avatar
lucky131969
https://www.corvetteforum.com/forums...k-message.html
Old Jan 14, 2025 | 03:16 PM
TPacifica's Avatar
TPacifica
Thank you. The battery is relatively new. A few months old. It died because of a parasitic electrical bleed from a Cobra Cam I have.I just need to clear this warning message. It is a distraction and makes if difficult to access other info this system supplies.
Todd
Old Jan 16, 2025 | 04:20 PM
Joshclifford84's Avatar
Joshclifford84
I've read and tried it all over the years, I still get the message 1-2 times every summer. It is what it is.
To Service column lock message
