Original water pump. Replace or not?
Old Jan 15, 2025 | 12:39 AM
2blklt4's Avatar
2blklt4
Default Original water pump. Replace or not?
Hello,
Recently surge tank hoses went bad, than radiator started leaking...all fixed now
Should I replace water pump preventevely?No leaks all working fine, original.
Btw, GM OEM still available?
1998, 95000 miles
Thanks!
P.S. Does the old saying...If it's not broken don't fix it applies here?
Old Jan 15, 2025 | 08:58 AM
lucky131969's Avatar
lucky131969
With some exceptions ......but by and large..yes. If you have a stock engine......the water pump is easy to change anyway. Leave it alone.
Old Jan 17, 2025 | 06:31 PM
A10Beav's Avatar
A10Beav
I say change it. You've already got everything drained and hoses out, it's easier to do it now. It could leak from the old gasket or a tired impeller.
Old Jan 17, 2025 | 07:45 PM
hyperv6's Avatar
hyperv6
Let it go if the damper has not been changed. That is the best time to do it.
To Original water pump. Replace or not?
