Blend Doors Malfunction
Old Jan 30, 2025 | 04:07 PM
blackvette58's Avatar
blackvette58
Default Blend Doors Malfunction
The blend doors malfunction on my 2002. Cold air from center vent and drivers side; warm air from passenger side. Recalibration did not resolve the issue. Heat is not important to me in Florida, is it possible to close, or partially close, the two passenger side vents without harming the HVAC?
Old Jan 30, 2025 | 04:39 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I’d take your car somewhere and let them scan it for trouble codes first.
Old Jan 30, 2025 | 05:19 PM
James Dean's Avatar
James Dean
It's likely the blend door actuator cracked the plastic gear on the inside. Happens to them using the GM one due to the plastic gear being pressed onto a metal rod for lack of a better explanation.
The Dorman replacement is a bit more durable, but make sure you get the one for the correct side.
The passenger side actuator does require removing the seats, battery, dashboard, and airbag.
You can remove the dash without pulling the seats, but just do it to give yourself much more room.
Old Jan 30, 2025 | 05:28 PM
blackvette58
Codes verified for each side.
Old Jan 30, 2025 | 05:30 PM
blackvette58
I assume they need to be replaced. Question focuses on a means to avoid the process.
Last edited by blackvette58; Jan 30, 2025 at 05:34 PM. Reason: additional information
Old Jan 30, 2025 | 05:34 PM
blackvette58
Reaseach: If your Corvette C5 is experiencing a faulty passenger side blend door actuator causing only warm air to blow, you can temporarily close the passenger side vents to manage the temperature without significantly impacting the overall HVAC system; this is a common workaround while you plan to replace the faulty actuator
Old Jan 31, 2025 | 04:50 AM
Moved to C5 Tech for comment.
Old Jan 31, 2025 | 10:09 AM
grinder11's Avatar
grinder11
Since I only drive my C5 in warm weather, I did an end run around this until I got new actuators. That would be cutting a heater hose and splicing in a petcock/shutoff valve near the coolant tank. Can't even see it unless you really look. That way no hot water can enter the cabin. You'll get nothing but cold A/C, if that is working. Oh, and even after I got new actuators, I kept the valve. Why? Because as hot as the C5 interior gets, it doesn't help that you have a 200° heating element in the dash at all times. If you ever need heat, it's only a hood raising and twist of the wrist away.....
Old Jan 31, 2025 | 11:16 AM
rrwirsi's Avatar
rrwirsi
When I had some issues with my blend doors, I took a flexible hose and inserted it through each side vent until it stopped (did not force). I hooked the hose up to a vacuum. Apparently some 'stuff' was sucked out since both have been working. For how long
To Blend Doors Malfunction
