I took the intake off to change the knock sensors, braided hose for the oil pressure sensor, and to change the gaskets. The knock sensor wires have been severed on the harness side. Was just the two connection points, and the cut wires barely sticking out. Can I run two wires to the ECU pinned at 11, and 51. Do I have to ground the wires too? Do I need a whole new harness. Should I give up, and take it to a mechanic? Help please. I would prefer to do the work myself cause I'm pretty sure a mechanic is just going to replace the entire engine harness. Much appreciated
I agree with merv. You can splice those wires just fine. Just to a good job. Also I'm not sure what you mean about grounding. Just repair the harness so it is like OEM.
Also be very careful replacing Gen 3 knock sensors. I have seen people replace perfectly good sensors because they think they are doing the right thing, only to induce never ended knock sensor codes. Auto parts store knock sensors are crap. Even the replacement Delphi or AC Delco knock sensor are crap.
As was mentioned....splice the wires and you'll be fine.
Depending on where the splice is, I highly suggest using either liquid electrical tape or the waterproof kind of heat shrink tubing if you have the space.
I don't use the regular kind of heat shrink tubing anymore...lesson learned from marine application.
I would also recommend soldering wires over crimping them, and yes, use shrink tubing. Thru the years I've had several crimped connections fail, or go intermittent, and some were crimped by "professionals." In all the soldered connections I've done in my 55+ years of doing this stuff, I've never had a soldered connection fail. Ever.....
Use marine heat shrink. Filled with goo that melts and seals the connection. I have used it on snowmobile trailer lighting for years with great results.
I use similar but they are aircraft spec. Those are great to use. The glue on the end seals and the tube hardens when it shrinks. Crimp the splice and put one of them on it's solid.
Are you talking about the RayChem Enviro Splices?
I've used those at work for a hundred years. They are probably the best crimp style splices on earth.
At home I am cheap ***. I splice by either solder and adhesive heat shrink or if I am in a hurry or without power I use the un insulated barrel crimps and adhesive heat shrink.
solder and heat shrink tubing,only use butt splices in temp/emergency ( automotive ) repairs.
What me and @Mr. Black are talking about are stuff that's MIL Standard accepted to run with military aircraft in the air. I use them on a daily basis at work because that's what I do. They aren't your normal butt connector and way better than soldering.
I have read all the horror stories I'm aware. The first knock sensor I put in broke off at the threading bolt with maybe 10lbs of pressure. It was fun fishing that out at the bottom of the cylinder. 🙄 I got two good ones as in they didn't fall apart when torquing.... Took the car to a mechanic to splice back into the harness. I'm comfortable splicing, but not on an engine harness that will cost me thousands of dollars if I eff it up.
I have read all the horror stories I'm aware. The first knock sensor I put in broke off at the threading bolt with maybe 10lbs of pressure. It was fun fishing that out at the bottom of the cylinder. 🙄 I got two good one...fingers crossed. Took the car to a mechanic to splice back into the harness. I'm comfortable splicing, but not on an engine harness that will cost me thousands of dollars if I eff it up.
Nah, you are overthinking this. It is just two wires in the main harness that are very long that should go to the pigtail I posted above. You can't eff this up that bad.
I wish I was there, we'd have this fixed up in minutes.
