What wheel offsets should i run?
Old Mar 18, 2025 | 01:27 PM
tropicc's Avatar
tropicc
5th Gear
Default What wheel offsets should i run?
I’m looking for the wheels to be flush the the fender/quarter panel but i’ve seen very varied results and numbers. i’m looking to go 19x9.5 in the front and 19x11 in the back but i’ve seen offsets range from factory to +30 on builds with the same wheel size (usually looking at 10.5 width in the back though). if anyone has any solid info or if yall can show me some of your builds with wheel sizes+offsets and tires that would be much appreciated!
Old Mar 18, 2025 | 01:56 PM
lucky131969's Avatar
lucky131969
https://www.corvetteforum.com/forums...s-and-tires-6/
Old Mar 18, 2025 | 02:58 PM
Missileboy's Avatar
Missileboy
+56MM on both front and back. OE replica rims. 19x10.5 (305/35) in the rear and 18x8.5 (255/40) in the front. Fit is flush.
Old Mar 18, 2025 | 08:28 PM
feeder82's Avatar
feeder82
This sticky from general has pics and specs
https://www.corvetteforum.com/forums...your-info.html
Old Mar 19, 2025 | 08:04 AM
USAZR1's Avatar
USAZR1
With a 9.5" width front wheel, I would probably go with a +53 offset. With a 11" width rear wheel, something in the +55 to +57 range. For tires, a 265/30/19 or 275/30/19 will work well. On the rear, a 305 tire will fit well.
My BC Forged 18x9.5 fronts with +50 offsets and 265/35/18 tire poke a tiny amount, maybe 1/8". The rear 19x11's were made so I could flush-fit a 325/30/19 tire so I went with a +66 offset.
To What wheel offsets should i run?
