C5 ac experts help!!
Old May 8, 2025 | 09:42 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Originally Posted by averyinfullerton
alright, heres where im at now, i discharged the system, and recharged it. using 1.63lbs as per the sticker. pressures were 35/350 so i shut it down. line was hot on low side. which indicates a blockage. im going to replace the orifice with the gm one with the brass piece in it. maybe i didnt clean the system out good enough.
Was a compressor failure the reason for doing what you have done?
Old May 8, 2025 | 11:26 PM
Eleven Bravo's Avatar
Eleven Bravo
I applied a vacuum pump to mine for 4-5 hours prior to charging. Maybe 45 min wasn't enough...
Old May 9, 2025 | 03:40 PM
averyinfullerton's Avatar
averyinfullerton
So I found my problem, I didn't clean out, Probably the condenser good enough. I blew it out, but I didn't flush it out with anything and now my orifice tube screen was totally clogged. so i'm hoping all the debris from the previous compressor was in the orifice, and now i'm going to vacuum it down, refill it. and try it again.
Old May 9, 2025 | 08:01 PM
frodo84's Avatar
frodo84
If your compressor failed I would replace the condenser, it's really difficult to get debris out of one. Just my opinion, of course. On the lighter side, HOPE is a four letter word. Good luck.
Old May 10, 2025 | 06:13 PM
averyinfullerton
that got it. clogged orifice. blowing cold af now. thanks for the help fellas!!
