HVAC Blend doors
Old Jul 28, 2025 | 07:50 PM
Secondchance2025's Avatar
Secondchance2025
7th Gear
Default HVAC Blend doors
MY gf has a 02 c5 and is having issues with the ac almost like it is stuck in the middle of defrost, floor and dash . The HVAC controller was replaced w a new one , and the procedure for setting it up done. MY ? is, on the build sheet it has a code CJ2 on build sticker , when I look it up the HVAC blend door is 250 bucks. Is ther only 1 or is there 2 blend door modules?? Alldata says there is 2 , but I want to make sure. I am hoping I don't have to ripe the whole dash apart. Thanks Joe
Old Jul 28, 2025 | 08:31 PM
lucky131969's Avatar
lucky131969
Stuck in the middle? ....as in air comes out of all locations regardless of mode selected?
Old Jul 28, 2025 | 09:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You and I have the same question.
BLEND DOORS control temperature. DAMPER DOORS control air flow at the different levels/modes.
If you cannot select what vents that the air comes out of, you have a damper door issue. If that's the case, VACUUM to the damper servo vacuum control module is suspect.
Old Jul 29, 2025 | 06:05 AM
Secondchance2025
7th Gear
Morning, the air is blowing out all 3 locations . I know the upper piece of plastic broke and wondering if something might be lodged in the duct work somewhere>>
Old Jul 29, 2025 | 06:59 AM
lucky131969
Old Jul 29, 2025 | 08:04 AM
redzg's Avatar
redzg
Two viable paths:
Take the car to a local Corvette specialist. And it really needs to be a knowledgeable Corvette mechanic, not just a good mechanic, not just a trusted mechanic. The problem isn’t terribly complex or remotely above the comprehension of a good mechanic, it just takes more time and less parts swapping than the average shop applies. A mechanic already familiar with the (common) issue will know what to test and where.
Option 2 (best!): go through this thread, even though it’s old and many of the photos no longer appear. Truly educational:
https://www.corvetteforum.com/forums...with-pics.html
Old Jul 29, 2025 | 08:21 AM
lucky131969
Originally Posted by redzg
Two viable paths:
That's an oldie but a goodie.
Old Jul 29, 2025 | 06:08 PM
grinder11's Avatar
grinder11
Two viable paths:
Agree 100%. It should also help, not eliminate, but help ensure that some out of production and hard to find plastic dash pieces aren't all broken to Hell and back.
To HVAC Blend doors
