camshaft
Old Aug 14, 2025 | 12:16 PM
Pavolc5's Avatar
Pavolc5
Default camshaft
Hi everyone, I’ve decided to replace my camshaft and I’m looking for advice on what parts and tools I’ll need for the job so I don’t forget anything. I’d also appreciate any tips or recommendations on what should be replaced or checked during the swap. I’d like to know if anyone here has experience with this specific camshaft and whether you think it’s the right choice. The seller told me that I don’t need to replace the torque converter or reprogram the ECU. My car is a 2001 Corvette C5, 56,000 miles, automatic transmission, base model. My goal is to increase performance, mainly for street driving at low to mid RPMs. The car is currently stock with no modifications. In the future, I plan to upgrade the rear differential, install long-tube headers, and get the car tuned. I’m starting with this camshaft, which was recommended to me by Summit Racing: https://www.summitracing.com/parts/cca-54-103-11 Do you think this is the right choice, or is there something better you’d recommend? Thanks!
Old Aug 14, 2025 | 12:28 PM
lucky131969's Avatar
lucky131969
Ok....you make it sound like you would replace the camshaft, and then get the car tuned sometime in the future...if so....not going to work out well.
You will be underwhelmed with a cam only change. Just not worth cracking the engine open for....in my opinion....especially if you do not plan on upgrading the heads.
You would be better served to add headers, upgrade the trans/TQ, and change the gear.....then get it tuned. Don't change the cam until you can upgrade the heads at the same time.
Old Aug 14, 2025 | 12:50 PM
Pavolc5's Avatar
Pavolc5
Yes, that’s exactly as you said.
First, I plan to replace the camshaft, and in the future, when maybe other modifications are done as well, I’ll have the ECU tuned.
The seller I mentioned told me that when switching to this camshaft, it’s not necessary to tune the ECU, as it works fine even with the stock tune.
I’m not planning to change the cylinder heads.
The seller told me that the camshaft adds about 30 horsepower and has the potential for up to 90 horsepower (probably with all the other upgrades).
I’d be happy to get advice on what kind of headers I should install.
Thank you.
Old Aug 14, 2025 | 12:56 PM
lucky131969
Thank you.
Good luck with that
Old Aug 14, 2025 | 01:19 PM
Pavolc5's Avatar
Pavolc5
Well, you didn’t really give me much advice you just made me more unsure but thanks for your opinion anyway.
Old Aug 14, 2025 | 01:32 PM
lucky131969
Seriously? I told you exactly how I would proceed. Perhaps you need to reread my post.
Old Aug 14, 2025 | 02:39 PM
Fast one's Avatar
Fast one
If you want increased low to mid street performance put a supercharger in and skip the rest.
Old Aug 14, 2025 | 02:47 PM
Pavolc5's Avatar
Pavolc5
[QUOTE=lucky131969;1609025920]Ok....you make it sound like you would replace the camshaft, and then get the car tuned sometime in the future...if so....not going to work out well.
Well, you told me that if I just replace the camshaft and don’t have the ECU tuned, it won’t end well.
That’s the exact opposite of what the seller told me. He claimed that there’s no need to adjust the ECU.
That’s why I’m confused now.
I’d also like your advice on which exhaust headers you’d recommend
Old Aug 14, 2025 | 03:12 PM
tabbruzz's Avatar
tabbruzz
If you do a cam you typically will need a tune...Perhaps, with no other mods like headers, intake, etc AND a super mild cam them perhaps you may not need a tune...But then, why mod it.......
Old Aug 14, 2025 | 03:16 PM
lucky131969
[QUOTE=Pavolc5;1609026278]
I just have a basic understanding of the C5 platform. You should probably just follow the advice of the seller. Nothing more to offer.
Old Aug 14, 2025 | 03:21 PM
Pavolc5's Avatar
Pavolc5
Originally Posted by tabbruzz
Ak si vyberiete vačku, zvyčajne ju budete potrebovať naladiť... Možno bez iných úprav, ako sú zvody, sanie atď. A s veľmi miernou vačkou, ju možno nebudete potrebovať... Ale prečo ju potom upravovať.......
Yes, it’s supposed to be a mild camshaft(I sent a link to which one it is) This is supposed to be my first step.Then, when I change the headers, intake, and rear differential, I’ll have the whole thing tuned on the ECU (at least that’s my plan ). I wanted to know if anyone has experience with this camshaft, if they’d recommend a better or cheaper one from someone else, and what I’ll need for the replacement so I don’t forget anything These are the things I’m curious about.
Old Aug 14, 2025 | 05:42 PM
C5Mat's Avatar
C5Mat
At the minimum you'll need a timing cover gasket set, a crank bolt, and cam retainer plate gasket. A lot of other while your in there stuff like timing chain, oil pump etc. Are you reusing the current lifters? If you pull the heads for new lifters then you will add more parts cost.
Old Aug 14, 2025 | 06:15 PM
CFight's Avatar
CFight
Do you have emissions testing? that per comp cams' site-
50 State Legal grind for the GM GEN III LS1/LS2/LS3 3 bolt engines. Bolt in with stock components and tune, can produce 30+ hp increase in peak power.
Seems if you are planning a tune you could step up to a tune required manf rated cam. They often list it on the listings^
Old Aug 14, 2025 | 11:32 PM
Markolc1981's Avatar
Markolc1981
While that camshaft is mild, and *maybe* you wouldn't need a tune, it is not the best advice to start your mods with a camshaft. For a larger camshaft to give you good results, it needs to more air (intake and exhaust). While youre stock intake is likely fine, the largest bottleneck (even for a stoc camshaft) is the exhaust, and that starts at the manifolds. You will gain just as much HP with Long Tube Headers as you would with that camshaft, for a lot less work, and money. There is a formula to follow to get the most out of a C5, it's best to follow to tried and true method, rather than sim upstream. Your car will behave better.
Unless you have a different reason altogether to want to change the cam that you have not told us yet, I would recommend to re-evaluate your plan.
Old Aug 15, 2025 | 01:34 AM
Pavolc5's Avatar
Pavolc5
Thank you very much for the advice.So, which exhaust headers would you recommend to me? I would then go for: headers – camshaft – differential – ECU remap.
Old Aug 15, 2025 | 02:07 AM
Smoken1's Avatar
Smoken1
Kook's are very popular (that's what I have) make sure that you get them coated
Old Aug 15, 2025 | 08:08 PM
grinder11's Avatar
grinder11
Pavolc5, Lucky is trying to tell you if you install a cam, you should get a tune. Even a stock car can gain power with a good tune. I don't care how mild your "mild" cam is, you'll never get the potential power level it can provide without a tune......
To camshaft
Old Aug 16, 2025 | 02:16 AM
Pavolc5's Avatar
Pavolc5
Yes, I understand that with proper tuning I can get the maximum out of it. But for me it’s a bit of a problem. I’m from Eastern Europe – nobody tunes Corvettes here. I have to find someone over there who can do it for me, and I want to have all the parts replaced first and only then get it tuned. Not like: change the camshaft – tune it, change the headers – tune it, change the differential – tune it.You see what I mean? (I’m translating this with ChatGPT ). I was also looking at those headers. The Kook’s are quite expensive. Do any of you have good experience with the Speed Engineering ones?
Old Aug 21, 2025 | 09:02 AM
grinder11's Avatar
grinder11
If you change the cam, and change the exhaust system (LT headers, axle back, etc.) along with other supporting mods WITHOUT tuning, you could also risk damaging the engine. The computer can only adjust so much and so far. I have seen motorcycle engines hole a piston due to guys that didn't know what they were doing re-jetting the carbs incorrectly. You state there aren't many tuners there, then say you'll find one after all the mods are done. So there must be a tuner around somewhere. If you're not going to drive the car while modding it, then that's the smart thing to do. If you tune and retune along the way, you'll be buying multiple tunes, which can get MIGHTY expensive. If youre going to do these mods and keep driving (if it even runs) it without a tune, you're asking for trouble. My .02, and good luck......
Old Aug 21, 2025 | 09:20 AM
Pavolc5's Avatar
Pavolc5
Hi, thank you for your reply. I’ve already learned that the cam I’m going to install will need to be tuned afterwards. Can you, or maybe someone here, help me with that? I need a good person who can tune the engine control unit. The problem is that nobody does it in my country, nor in the neighboring ones. That’s why I need someone who can do it remotely.Is there such a person?
