A/C lines?
The previous owner removed some a/c lines and the condenser. Can someone please steer me in the right direction and tell me what lines to order and or part numbers?
Thanks- Brandon
IF everything was removed, by memory, you will need:
Suction/Discharge hose assembly which connects from the A/D to the compressor and from the compressor to the Condenser inlet
Liquid line from the Condenser to the Evaporator
Evaporator outlet to the A/D inlet
Other parts you will need:
Accumulator/Dehydrator (A/D)
Orifice tube
O-rings and seal washers for the compressor
Flush solution for the evaporator and anything else that had been open to the atmosphere
If the compressor has been left unsealed, it may be corroded internally
It looks like they left #2 in that diagram
