WIX filter/regulator
Old Aug 17, 2025 | 07:36 PM
RonSSNova's Avatar
RonSSNova
Default WIX filter/regulator
I see these are once again available? Seems to me they weren’t for awhile.
Are they good?
I ask because I suckered for a Walbro pump Wix C5 filter kit on eBay a couple years ago for the LS1 in my son’s S10.
Neither were legit parts. No name crap. Pump failed in short order. The fuel pressure was close to correct at 55 psi running.
With the correct pump, fuel pressure is now 75 psi. Discovered after I converted to a card style MAF and had tuned the truck.
Ron
Old Aug 19, 2025 | 04:45 AM
James Dean's Avatar
James Dean
I've sourced them through reputable parts dealers, actual GM dealers, Summit, and Rock Auto
All of them seem to fail in similar fashions and deliver inconsistent pressure. Some out the gate have 66-72psi where others idle properly but lower fuel pressure with RPMs.
Old Aug 19, 2025 | 02:05 PM
RonSSNova's Avatar
RonSSNova
Well….we have a WIX on the way. If not correct, I’ll just get an adj regulator and an inline filter and do it the old fashioned way. A bit of replumbing but not bad.
Old Aug 20, 2025 | 04:16 PM
grinder11's Avatar
grinder11
Are they good?
Ron
Hey, Ron. Does this mean you got that 100mm MAF to fit??
Old Aug 20, 2025 | 06:24 PM
RonSSNova's Avatar
RonSSNova
Both my C5 and my Sons S10 now have LS3 car style MAF’s.
Old Aug 21, 2025 | 08:29 AM
grinder11's Avatar
grinder11
Is the LS3 MAF 100mm? I have the Vararam setup, and I can't help but think the 85mm LS6 MAF is somewhat choking the bigger motor....
Old Aug 21, 2025 | 10:53 AM
RonSSNova's Avatar
RonSSNova
You could call it 100mm as in both my cases the MAF is mounted in a 4” tube.
This is the S10
Old Aug 21, 2025 | 04:18 PM
grinder11's Avatar
grinder11
Ron, I remember talking to you before about you having a 100mm MAF sensor, but couldn't make it fit due to the long length. I assume you still have it and never did get it installed, correct? IIRC, that was more like the stock C5 MAF, but 100mm vs 85mm?
Old Aug 21, 2025 | 06:47 PM
RonSSNova's Avatar
RonSSNova
I got it in last year. Along with GM LS3 injectors.
I just didn’t post anything.
I haven’t got it to the track yet to do WOT tuning.
It’s a little crude as the Vararam lid outlet is 3.6” vs the 3.9” id of the MAF tube. But I scored another Vararam lid that I’ll modify to fit the 4” tube. I just need to figure out how to do it.
Track date for Sept 6, I’ll have it done by then.
it will do one of 3 things.
1. Go slower
2. Go faster
3. Run the same.
Ha!
Old Aug 26, 2025 | 10:45 PM
RonSSNova's Avatar
RonSSNova
Installed the new WIX from Summit.
90psi key on….******* lovely.
WIX now made in Taiwan
Old Aug 28, 2025 | 05:39 PM
grinder11's Avatar
grinder11
Yeah, I remember Wix was sold recently to a Chinese company. They must farm it out to Taiwan.....
Old Aug 28, 2025 | 05:46 PM
grinder11's Avatar
grinder11
Ron, IIRC you were also running the 85mm LS6 MAF, too. I'm subscribing for the new strip numbers. If it helps your 383, it should also help my 427.....
To WIX filter/regulator
