C5 wheel fitment again
Old Aug 22, 2025 | 05:19 PM
PapaFred's Avatar
PapaFred
Default C5 wheel fitment again
Do OEM C7 Corvette grandsport rims fit a C5 with no mods?? refer to other link or move me if needed...Thanks all
Old Aug 22, 2025 | 05:41 PM
lucky131969's Avatar
lucky131969
https://www.corvetteforum.com/forums...s-and-tires-6/
Old Aug 22, 2025 | 05:56 PM
PapaFred's Avatar
PapaFred
Is there a sticky on what wheels fit our cars? By the time I read through every post I'll be 81
Old Aug 22, 2025 | 06:06 PM
lucky131969
https://www.corvetteforum.com/forums...s-on-a-c5.html
Old Aug 23, 2025 | 09:35 AM
PapaFred's Avatar
PapaFred
thank you Lucky, that helps a lot
Old Aug 23, 2025 | 07:47 PM
USAZR1's Avatar
USAZR1
C7 Grand Sports are widebody cars so even though those wheels will bolt on a C5 with oem fenders, the fit leaves a little to be desired. The front wheels are 19x10's with +43 offset, which will cause poke The rears are 20x12's with +59 offset, too wide to fit under an oem C5 fender, which results in noticeable poke, as well. Base C7 front wheels will fit fine. The rears will too, with the addition of a 20mm spacer.
Old Aug 23, 2025 | 07:51 PM
PapaFred's Avatar
PapaFred
Got it thank you..I think I will just go with the Spec Corvette wheels. They look great like the original C5 factory wheels and supposed to fit narrow bodies.
To C5 wheel fitment again
