Hello all
Old Aug 29, 2025 | 01:28 AM
Coma's Avatar
Coma
5th Gear
Default Hello all
Hello everyone. I need some help. Finally saved enough for a used type M EBCM unit for my 98 C5 . After I installed it my codes read TCS no communication it also reads
HVAC no communication. What can I do to fix this. There are a couple more codes I'm working on but do not have them with me at the moment. Any help is much appreciated thank you.
Old Aug 29, 2025 | 01:38 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I can help right away by moving you here for further discussion... good luck
Old Aug 29, 2025 | 07:02 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Check power and grounds for both modules…you can start there.
Old Aug 29, 2025 | 07:41 AM
lucky131969's Avatar
lucky131969
Front or rear mounted EBTCM?
What led you to believe the EBTCM was bad? What codes did you have? Did you have TCS "no comm" with the old EBTCM? Did the HVAC work normally before changing the EBTCM? Besides "no comm" what other codes do you have now?
Old Aug 29, 2025 | 12:29 PM
Coma's Avatar
Coma
5th Gear
Hello and thank you for your reply. My type M EBCM went out about 4 years ago. I took it out and was going to try and repair it. However the motherboard was fried beyond repair. Now I finally found one for $1500 bucks and took the old one back out and put this one in. But the traction control and ABS lights stayed on and the button did nothing so I asked around and found out how to pull my codes myself. Im not a mechanic in any way. But I've been learning lol. Anyway I pulled my codes and this is what I have.
10-PCM-P1571 HC
10-PCM-P1644 HC
THERES 4 OTHER CODES THAT pulled up at first but I reset them and they haven't came back yet, then I have
28-TCS-NO COMM.
40-BCM-BO432 HC
99-HVAC-NO COMM.
80-RFA-C2120 HC BUT THIS ONE I RESET AND IT HASNT CAME BACK YET. Im getting ready to drive it a bit and pull my codes again my A/C doesnt work thats my next project and i need to replace my relay for my blower / heater motor i think ​
Old Aug 29, 2025 | 12:50 PM
lucky131969
10-PCM-P1571 HC
10-PCM-P1644 HC
28-TCS-NO COMM.
40-BCM-BO432 HC
99-HVAC-NO COMM.
That did not answer all the questions I had...but..ok.
I would be investigating your ignition switch based on the codes you have. Good luck.
Old Aug 29, 2025 | 09:26 PM
kkupec02's Avatar
kkupec02
Welcome!!
Old Aug 31, 2025 | 12:16 AM
Coma's Avatar
Coma
5th Gear
[QUOTE=lucky131969;1609061770]That did not answer all the questions I had...but..ok.
im sorry for not answering everything . I didn't catch the first question. I guess you'd say it's a front mount because it's just under the power steering and between the radiator and main pullies
Old Aug 31, 2025 | 11:35 AM
helga203's Avatar
helga203
[QUOTE=Coma;1609064913]
Used ones are not guaranteed to work. Some ventory say buy at your own risk. Not worth taking the change. If its not a power or ground issues your back to square one.
And i believe 97-2000 can not be fixed.
Old Sep 1, 2025 | 06:13 PM
Coma's Avatar
Coma
5th Gear
I think i found a guy that said he can make me a new board by looking at my old one. But he also said my old one was fried beyond repair. But it's a simple board to make. So now I wait but I'll still try and get this one to work also they said they tested it and it was ok. Thats all i know
Old Sep 1, 2025 | 06:39 PM
eric22's Avatar
eric22
And what codes and problems did you have with the earlier module.
Old Sep 2, 2025 | 09:03 PM
Coma's Avatar
Coma
5th Gear
I don't know what codes came up back then but my abs and traction. Control lights were on. I watched a video on how to fix it and when I took it out I realized it was different from the others and how bad it was.
To Hello all
