LMC5 Pull Key Error still occuring
Old Nov 11, 2025 | 01:13 PM
lucky131969's Avatar
lucky131969
Originally Posted by DinoBob
Just no need. This is not the battery causing your issue. Do the brown wire mod. You’ll thank me.
Old Nov 11, 2025 | 01:42 PM
MyNameIsTerry's Avatar
MyNameIsTerry
Ok will give that a go and circle back. Thanks for the input.
Old Nov 11, 2025 | 05:36 PM
Supercharged111's Avatar
Supercharged111
Another vote for the brown wire mod, mine needed that too.
Old Nov 11, 2025 | 06:29 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by MyNameIsTerry
I was thinking of swapping out with optima red top regardless. Thoughts?
Yes...get a yellow
Old Nov 12, 2025 | 07:12 AM
VetteLooking's Avatar
VetteLooking
...and to beat the dead horse: brown wire mod.
Worked for me as well. I honestly dont know why it is not part of the base instructions. It does not seem to have any downside, so it makes sense to take the extra 5 minutes to do and to ensure the issue is avoided. I originally followed the instructions not to and had to go back into it later after getting the fuel cut a few times.
Old Nov 12, 2025 | 08:31 AM
lucky131969
It is! Post #13 shows the screenshot from the LMC5 instructions.
Old Nov 12, 2025 | 08:21 PM
VetteLooking
I think you meant post #15, but that is my point. It has "Optional", "Only do this if you have issues after the install", and other indications you shouldn't need to do it as part of the base install. What it doesn't say why you shouldn't go ahead and do it right away to avoid rework.
It seems the need to do this mod is more common than the text would lead one to believe.
By "base" instructions, I meant to say that it should be part of the main instructions and not an optional step.
Old Nov 13, 2025 | 07:10 AM
lucky131969
Right, but all configurations are not the same....
Old Apr 13, 2026 | 09:22 AM
MyNameIsTerry
Following up after issue resolved. We tried doing the brown wire mod on the already installed module but that didnt work. The support team finally got back to us and suggested to redo the install with a new module and apply the brown wire mod at that time. That did fix the issue. Thanks all for the suggestions.
Old Apr 13, 2026 | 11:30 AM
frodo84's Avatar
frodo84
Uneducated autodidact
Thank you for following up!
Old Apr 15, 2026 | 07:41 AM
redzg's Avatar
redzg
Agreed! Simply ludicrous how many threads simply stop with no conclusion. Possibly including one or two of my own…
