Help. Not starting
Old Nov 24, 2025 | 07:04 PM
RicardC5's Avatar
RicardC5
Default Help. Not starting
Hello all!
I had this issue just now. Battery checked, okay.
The shifter is moving easily. Looks like it's stuck in Drive gear, not allowing to start.
https://youtube.com/shorts/YLVAxZyD6cU?si=j0GgV9o0Ec3vlWKL
Could someone help me, please?
Old Nov 24, 2025 | 07:26 PM
Ltngdrvr's Avatar
Ltngdrvr
So, the little plastic clip on one end of the shifter cable or the other is broken, so the trans is not shifting to park or neutral, so it won't start.
And, if it did, you couldn't drive it anyway, since it will not shift into the proper gear.
Do a search on here for broken shifter cable.
Old Nov 24, 2025 | 09:23 PM
RicardC5's Avatar
RicardC5
yes, it's.
And I found only a way to replace the cable, lifting the vette and removing the muffler.. s&#t! Thank you anyway!
Old Nov 24, 2025 | 09:52 PM
Ltngdrvr's Avatar
Ltngdrvr
Here are a couple of repair articles...
https://www.hotrod.com/how-to/repair...ic-shift-cable
https://www.motortrend.com/how-to/18...c-transmission
Old Nov 25, 2025 | 01:06 AM
RicardC5's Avatar
RicardC5
Great! I purchased the bushing on Amazon.
However, before seeing these articles, I didn't realise the cable was fragile. When I pulled it up to inspect the bushing conditions, I heard a "crack", indicating that some plastic had broken...
I had secured the end of the cable with a zip tie for now, but I don't know the extent of the damage caused when I broke the cable while pulling it up. I'll check when I open it to replace the bushing.
Thank you!
Old Nov 25, 2025 | 09:07 AM
Ltngdrvr's Avatar
Ltngdrvr
Thank you!
Be sure to check the transmission end of the cable too, it is very close to the exhaust, so the heat can kill the plastic end.
The shift cable setup was not one of GM's better engineering accomplishments.
Old Nov 25, 2025 | 10:52 AM
RicardC5's Avatar
RicardC5
For that, I need to lift the vette... I'll buy a ramp or jacks.
I was reading, even Chevy and GMC trucks have the same issue, but they are easier to access and replace.
Which do you guys think is better to have access underneath in a small garage?
Hydraulic
Jack
I think the links didn't work...Following the full links - they are still not working... I don't know how to post links here... So, here are Screenshots, sorry for my ignorance.
https://www.amazon.com/dp/B0DQXNF3VQ?linkCode=ogi&th=1&tag=soffers com2-20
https://www.amazon.com/Profile-Repair-Racing-Single-Lifting/dp/B0CLXLJWXW/ref=sr_1_18?crid=1SVHDVL0G2T1H&dib=eyJ2I joiMSJ9.V4wl-HqrLBpV91AT7HmMMsTAQzfJJZAtQ-Wo4RFgPtr8MLygLp6XUTCnlX621nmC12xW967OEG LIzE_jVbZlc139d1P6PIhSTfUmwjMpLnE7MjA7y3 A83y9AS7qUItjyQWIDOp1zbePkhWlLvOzdVvnH0z WdoKZG7Hiupx_OygAOk-X2CM_2YkTifFJ4QRH6gZDB2rzj9a2S4V05jVroXk Lc9A0AECjFubo7a7tYc5fCzoZoSEBdqNdSnYYJ5K 33LQVzD-40iGXMG-wfRXa5lJSMASg9F_XvMRCacbLJMOM.-Yo6-c-eEyzwy9v2tWj_HTjEppZW7qe-sLHhBu_HJZY&dib_tag=se&keywords=car%2Blo w%2Bprofile%2Bjack&qid=1764085842&sprefi x=car%2Blow%2Bpr%2Caps%2C165&sr=8-18&th=1
Old Nov 25, 2025 | 12:07 PM
Ltngdrvr's Avatar
Ltngdrvr
Personally, I would not do either of those setups.
I use a low profile HD floor jack and jack stands I bought from Harbor Freight.
Much heavier duty than those you posted, stout enough to do jobs on my F250 as well.
Too much strength is better than too little.
Old Nov 30, 2025 | 07:44 AM
donjetman's Avatar
donjetman
Installed new shifter cable, AC Delco # 12561688 – amazon $68
Old Nov 30, 2025 | 07:55 AM
Moved to C5 Tech.
Old Nov 30, 2025 | 11:59 AM
feeder82's Avatar
feeder82
Race Ramp brand, rock solid, they don't slide.
Old Nov 30, 2025 | 02:46 PM
RicardC5's Avatar
RicardC5
Purchased it and left at mechanic shop for replacement.
I'll buy these, but for the cable replacement I preferred do it in a mechanic shop. But the guy is crazy busy. My verte is there since Friday.
To Help. Not starting
