Oil Pressure
Old Jan 19, 2026 | 10:38 AM
BlackBetty2002's Avatar
BlackBetty2002
1st Gear
Default Oil Pressure
Hello,
I seem to remember my question being answered but can't find it. While giving my C5 a winter start up i see that oil pressure is pegged at 80lbs. Even after coming up to temp. Any Ideas?
Dan
Old Jan 19, 2026 | 10:55 AM
mmartinez's Avatar
mmartinez
Oil pressure sensor has failed.
Old Jan 19, 2026 | 12:31 PM
Ltngdrvr's Avatar
Ltngdrvr
Yup, likely a bad sensor.
You could use a manual gauge to test it, or just replace the sensor.
Old Jan 21, 2026 | 11:57 AM
vito02's Avatar
vito02
Originally Posted by BlackBetty2002
Hello,
I seem to remember my question being answered but can't find it. While giving my C5 a winter start up i see that oil pressure is pegged at 80lbs. Even after coming up to temp. Any Ideas? Dan
If the pressure indication stays pegged high even at hot idle, I agree likely a failed sensor. But I would still check the pressure with a mechanical gauge. There are adapters that can be made or purchased that allow pressure testing at the oil filter.
To Oil Pressure
