Throttle body recommendations
Old Apr 2, 2026 | 10:22 PM
jonnyaust's Avatar
jonnyaust
Default Throttle body recommendations
I just acquired a msd intake manifold with and ls2 fuel rail and 36lb injectors.
what throttle body should I get ? I was thinking a ls2 silver blade
car is stock with a full exhaust system
Popular Reply
Apr 3, 2026, 11:30 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Good tuner I guess. I just bolt stuff on and hand it to him to figure out, lol.
Old Apr 3, 2026 | 12:11 AM
vette4fl's Avatar
vette4fl
You doing this just for appearance, or plans for big heads a rocking cam?
Old Apr 3, 2026 | 12:56 AM
jonnyaust's Avatar
jonnyaust
just too good of a deal to pass up but plans for some nice heads and a decent cam in a year or two
Old Apr 3, 2026 | 01:01 AM
arthursc2's Avatar
arthursc2
The only OEM larger upgrade that's been proven to work, be reliable and not have weird repin, tune nuances, reduced engine power- you name it-
is the LS2
others claim a gold blade can work, if it's the perfect gold blade, built exactly at 1:10pm on a Friday the 13th, but only in 2007- and then you just have to reset the REP every once in a while 🙄
get an LS2 silver blade and rock on. Conversion harness is super cheap, proven, reliable, no dumb **** to deal with in the tune or under the hood
Old Apr 3, 2026 | 09:16 AM
Kubs's Avatar
Kubs
is the LS2
I have had zero issues with my gold blade for 3 seasons of track use. My tuner had to limit throttle opening but thats it. The REP comes from the over travel.
Old Apr 3, 2026 | 10:26 AM
jonnyaust's Avatar
jonnyaust
is the LS2
and I assume I need an adapter plate to go from 103 to 90?
Old Apr 3, 2026 | 10:46 AM
Kubs's Avatar
Kubs
Nope. I ran my 90mm on a FAST 102. Bolt pattern is the same and there is enough meat to seal the gasket.
Old Apr 3, 2026 | 11:26 AM
arthursc2's Avatar
arthursc2
For the written record- Kubs is the first I've read about, and maybe only- guy that has claimed success with the gold blade on an 0411 and stock TAC
Old Apr 3, 2026 | 11:30 AM
Kubs's Avatar
Kubs
Old Apr 3, 2026 | 11:35 AM
helga203's Avatar
helga203
Mr. Black has a write up on these and he was successful without a tuner. There's a vid on here that was just shown.
Old Apr 3, 2026 | 12:00 PM
arthursc2's Avatar
arthursc2
Last I heard he was struggling with REP messages. If he got it sorted out, that's wonderful for him! It opens up a plethora of inexpensive TB options for Gen 3 guys
Old Apr 3, 2026 | 01:58 PM
Fcar 98's Avatar
Fcar 98
I don’t know what HP you are planning. Years ago SLP told me that the stock LS1 throttle body was good up 500 HP.
Old Apr 3, 2026 | 02:45 PM
helga203's Avatar
helga203
P.S. he tunes it himself he his HPTuners so you need to have tuning software. Just to clarify.
Old Apr 3, 2026 | 03:51 PM
vette4fl's Avatar
vette4fl
Thats the preferred method, lol 😆
Old Apr 3, 2026 | 04:15 PM
jonnyaust's Avatar
jonnyaust
not planing on crazy power but the guy that sold it to me has his stock ls2 one can get it for a decent price so why not
Old Apr 3, 2026 | 04:35 PM
vette4fl's Avatar
vette4fl
Well, because your engine doesn’t need it? Not meant as a criticism, but you did ask…
It won’t hurt your power, but you’ll want to get it re-tuned. Perhaps hold off until you do heads and cam and get everything tuned in one session. I have failed follow my own advice on that, lol, and it’s costly. Enjoy your project 👍
Old Apr 3, 2026 | 11:33 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Doing everything at once will save you $$$. Considering that the throttle body by itself won't really get you anything, it makes sense to wait until you're ready to do heads and cam all at once with one tune.
To Throttle body recommendations
Old Apr 4, 2026 | 04:20 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Second one here. I ran a gold on my last 99 coupe for many years on a Fast92 with a P1-Sc setup. Zero issues once tuned correctly. Several REPs before then. The tune fix came from Doug @ ECS who set the throttle signal limit to 97% or similar if memory serves. The blade itself still reaches 100% opening, but the signals sent/returned now function in the C5 ecu. The same info has been commented on the forum in the past. When I went back to NA on that car I recall copying the setting in EFI Live and it continued to work on otherwise factory original tune with a few tweaks like no torque limit between shifts, earlier fans to keep coolant temps down, etc.
Old Apr 4, 2026 | 09:53 AM
JHrinsin's Avatar
JHrinsin
As I noted in another thread, swapping from the 78mm LS6 throttle body may not be 100% needed unless the engine has some other mods that results in the 78mm throttle body becoming a flow restriction. Now mine specifically was a before and after; before was a LPE ported 78mm throttle body on a stock LS6 intake and after was a ported LS2 silver blade throttle body on the TPIS modified 90mm snout LS6 non ported intake. We saw zero real change in peak power numbers, the combo made 402 rwhp with 392 lbs-ft torques SAE standard on a DynoJet. As always, YMMV.
https://www.corvetteforum.com/forums...post1609470027
Old Apr 4, 2026 | 12:47 PM
Moved to C5 Tech.
