Jacking pucks
Old Feb 25, 2003 | 06:06 PM
David Plum's Avatar
David Plum
Default Jacking pucks
Make your own jacking pucks out of hockey puck and 1 inch round 2 inch long eyehole screw I heated the eye hook and made it oval screwed hook into center of puck fits in frame turn 90 degree's stays in works great on a lift. Made them for about $ 10.00 sorry no pics no dig camera
[Modified by David Plum, 11:08 PM 2/25/2003]
Old Feb 25, 2003 | 06:34 PM
Oldvetter's Avatar
Oldvetter
Default Re: Jacking pucks (David Plum)
I use solid aluminum ones, I don't like how the hockey pucks flex.
Old Feb 25, 2003 | 06:50 PM
HummelS's Avatar
HummelS
Mine - I used 5/16" wing screws from HomeDepot:
Old Feb 25, 2003 | 07:47 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: Jacking pucks (thevettenet CA)
I don't use them at all. The disc on the jack I use fit's perfectly into the jacking spot....$18 at Wal-Mart....works GREAT! :cheers: :thumbs:
Old Feb 25, 2003 | 07:53 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Default Re: Jacking pucks (Oldvetter)
:iagree:
Old Feb 25, 2003 | 07:58 PM
chocoholic's Avatar
chocoholic
Default Re: Jacking pucks (Mike98SilVert)
The double decker ones are less likely to flex. There's a good article here on how to make them: http://97vette.com/howto/liftpads/index.html
Old Feb 25, 2003 | 09:03 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Jacking pucks (chocoholic)
Cabinet ***** at Home Depot
Old Feb 26, 2003 | 05:49 AM
vettenuts's Avatar
vettenuts
Default Re: Jacking pucks (wallstAL)
I have the hockey pucks that I use for various jobs, but I carry the aluminum ones in the car. My feeling is that if you need service on the road, a shop won't use the hockey pucks but will use the aluminum ones. It is also very likely they won't have either so you need to carry your own IMO. :thumbs:
To Jacking pucks
