HID Install Help Needed
Old Feb 26, 2003 | 10:50 AM
BLU99VETTE's Avatar
BLU99VETTE
Default HID Install Help Needed
I just installed some 8000 HID's on my C5. These are 9006 bulbs with HID ballast's. The problem is that when I turn my lights on they go on for 2 seconds and then off. I am not blowing any fuse's and I went from the 10amp fuse all the way up to a 30 and still the same thing. Can anyone offer any advice. :nopity Feel free to email me at work.. Rgds..
t.mcnabney@us.lvmh-fashion.com
Old Feb 26, 2003 | 01:56 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Default Re: HID Install Help Needed (BLU99VETTE)
BLU99VETTE,
GM vehicles are affected by reverse polarity on their wiring, so unplug the 9006 low beam factory socket from the HID ballast, rotate it 180 degrees and plug it back in. It should start working.
If that doesn't work, make sure your car is running when you fire up the HIDs. HIDs require higher voltage to get the ballasts to ignite.
Also, don't go as high as 30 amps on the headlamps fuses. 15 works just fine.
8000k is highly illegal in the U.S. You can get away with 4200k or even 5000k, but 8000???:eek: They are going to be too much on the deep purple side and law enforcement will probably come down on you for that.
Hope this helps.
Shawn
[Modified by L.A.P.D., 10:59 AM 2/26/2003]
Old Feb 28, 2003 | 11:16 AM
BLU99VETTE's Avatar
BLU99VETTE
Default Re: HID Install Help Needed (L.A.P.D.)
Thanks LAPD.... You were right on.
To HID Install Help Needed
