Gear Oil
Old Mar 2, 2003 | 12:54 AM
boost2much's Avatar
boost2much
Default Gear Oil
Is it OK to use Redline MT90 for the differential? On the side it says its a 75W-90 gear oil and that's what my parts store gave me. Last time I used the Redline 75W-90 but now they gave me this. Its also red in color vs. the regular brownish color. I sure hope I don't need to drain my diff. and replace it. The stuff sure isn't cheap ;) :cheers:
Old Mar 2, 2003 | 09:44 AM
vettenuts's Avatar
vettenuts
Default Re: Gear Oil (boost2much)
No, you should use the 75W-90. Take this stuff back. The MT90 is GL-4 and the 75W-90 is GL-5. Don't use it.
Old Mar 2, 2003 | 11:43 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: Gear Oil (vettenuts)
________________________________________ ________________________
:iagree: .....Bob T is right, they gave you the wrong oil.....Sounds like you already changed it...It's their mistake.....good luck.
Old Mar 2, 2003 | 05:20 PM
boost2much's Avatar
boost2much
Default Re: Gear Oil (vette#one)
Thanks guys, I put the stuff in already so I guess I have to drain it :nonod: Could this cause the diff. to leak? I have a slight leak around the passenger side drive shaft.
Old Mar 2, 2003 | 05:21 PM
boost2much's Avatar
boost2much
What is the difference between GL-4 and GL5?? Just curious. :cheers:
Old Mar 2, 2003 | 05:27 PM
IMQUIK's Avatar
IMQUIK
:iagree: He knows his shiat!!
gmblack3's Avatar
gmblack3
The leak is a warranty fix. Common problem on C5s Take it in and let them change the fluid.
Old Mar 2, 2003 | 05:32 PM
IMQUIK's Avatar
IMQUIK
Here ya go! :D
http://www.motorvate.ca/auto/general/GL.htm
Old Mar 3, 2003 | 12:31 AM
boost2much's Avatar
boost2much
Default Re: Gear Oil (gmblack3)
Problem is the leak is on my 4.10s so I don't think they will fix it under warranty ;) What is the cause of the leak and the fix?
To Gear Oil
