engine rattle when turning off the ignition
Old Mar 9, 2003 | 03:06 PM
slxrti's Avatar
slxrti
Default engine rattle when turning off the ignition
Hi I noticed when I turn off the ignition the engine shutters and kinda rattles.
This seem to occurs after a hot shut down. I don't notice this when cool.
Any idea what the cause?
slxrti
Old Mar 9, 2003 | 03:33 PM
nozebleed's Avatar
nozebleed
Default Re: engine rattle when turning off the ignition (slxrti)
I noticed mine does this more now that I have a cam installed. Maybe it's the extra lift or duration of valvetrain.
Old Mar 9, 2003 | 04:10 PM
kh24's Avatar
kh24
Press in the clutch when you turn off the car and it should not rattle. :cheers:
Old Mar 9, 2003 | 07:25 PM
Beltrami's Avatar
Beltrami
you might be experiencing "dieseling" <sp?> this happens when the octane of the fuel in not correct, i.e, high enough, try filling up at a different station.
i
Old Mar 9, 2003 | 08:06 PM
C5inWV's Avatar
C5inWV
Default Re: engine rattle when turning off the ignition (kh24)
:iagree:
Old Mar 9, 2003 | 08:11 PM
Dave00C5's Avatar
Dave00C5
Default Re: engine rattle when turning off the ignition (Beltrami)
i
:iagree: Also called engine run on, not a good thing, try better fuel!
Old Mar 10, 2003 | 02:24 AM
slxrti's Avatar
slxrti
it does seem like it dieseling, but the dealer said they all rattled. hmm
By the way it occurs regardless of which brand of gas.
slxrti
Old Mar 10, 2003 | 03:54 AM
Racer1x's Avatar
Racer1x
It is normal if you baby the car around and not bring it up in the rpm's,you will notice it. My cure is to run the car up in the rpm's every once in a while and it will not do it. Ok I lied I bring the rpms up every chance I get :D
Old Mar 10, 2003 | 02:58 PM
Duck916's Avatar
Duck916
Modern fuel injected vehicles should not be capable of dieseling, since the fuel is shut off when you turn the key. With a carbureted engine you can get dieseling since the fuel in the carb float bowl can still be sucked into the motor.
Old Mar 10, 2003 | 08:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: engine rattle when turning off the ignition (Duck916)
Its NOT dieseling but has alot to do with the dampening springs in the clutch disc. When the enging shuts down the engine stops firing and the pistons are slowed down by compression. When the engine spins down to a very slow speed the crank shaft will start to hunt between compression and vacuum in the cylinders and cause the dampening springs in the clutch disc to go from fully loaded in one direction to fully loaded in the opposite direction.
That my theory! :D Ive tried every technique known to man to figure it out and YES pushing in the clutch will HELP eliminate the noise. If anybody else has a theory lets hear it. It happens in my 98 and 02 ZO6.
Old Mar 10, 2003 | 10:33 PM
redls1c5's Avatar
redls1c5
Default Re: engine rattle when turning off the ignition (Bill Curlee)
I have a similar noise. I thought it was the bearings in the drive-shaft (are there any?) I noticed it doesn't make the noise if I shut down with the clutch pedal pressed in. Pretty noisey though.
Old Mar 10, 2003 | 10:36 PM
SlumpinC5's Avatar
SlumpinC5
Default Re: engine rattle when turning off the ignition (redls1c5)
I have some noise when I turn off the car too.. Thought it might be something loose thats kinda what is sounds like...I will try pressin the clutch and see if thats it.. Nothing to worry about I guess right?
Old Mar 10, 2003 | 10:37 PM
Monster231's Avatar
Monster231
:iagree: :iagree: that is exactly what is happening, i think, mine does it too
Old Mar 10, 2003 | 11:33 PM
jmX's Avatar
jmX
Default Re: engine rattle when turning off the ignition (Monster231)
Definitly not deiseling. Its normal. Don't worry about it.
Old Mar 11, 2003 | 02:29 PM
DSTJ99's Avatar
DSTJ99
Default Re: engine rattle when turning off the ignition (jmX)
97 with 19,000 miles and i've been wondering about this for a while. Great to hear it common and just one more C5 quirk :skep:
Old Mar 11, 2003 | 02:52 PM
Mark S.'s Avatar
Mark S.
Default Re: engine rattle when turning off the ignition (DSTJ99)
Very common, just press in the clutch (put the gear selector in 1st or Rev...I use Rev) and then turn the ignition off...wait a second and then release the clutch.
Old Mar 11, 2003 | 03:15 PM
elric's Avatar
elric
I noticed the same thing. I will have to try using the clutch also. Another thing I noticed is the clutch is very loud. If I am sitting idle and I just press in the clutch and let it go, there is a loud sound (I think it is just the flywheel spinning up, but I just got my car Sunday and wanna be sure).
I must say, I love my 03 Vette alot more then my 02 Acura I traded in
It is an amazing vehicle :flag
To engine rattle when turning off the ignition
Old Mar 11, 2003 | 03:23 PM
kh24's Avatar
kh24
Default Re: engine rattle when turning off the ignition (elric)
Its the throwout bearing making that noise. It will quiet down with more miles. Just press in the clutch and hold it in while you turn off the ignition and the rattle will go away. :cheers:
Old Mar 11, 2003 | 03:25 PM
SideStep's Avatar
SideStep
:thumbs: :iagree:
Old Mar 11, 2003 | 06:10 PM
C5B's Avatar
C5B
:iagree: :yesnod:
